Logging EMAP and fuel pressure
Subscribe
Sep 13, 2014 | 05:05 PM
Using neptune and get my EMAP setup using a general 75psi sensor and i know you have to use the first bar for atmospheric pressure and the remaining 5bar for pressure, but when setting up a basic 0-100 psi sensor for fuel pressure, do you have to do the same?
Reply 0
Sep 13, 2014 | 06:21 PM
Re: Logging EMAP and fuel pressure
No. Any fluid pressure would be 0-100 psi .5-4.5 volts generally with most 100psig transducers.
Reply 0
Sep 13, 2014 | 07:57 PM
Quote: Using neptune and get my EMAP setup using a general 75psi sensor and i know you have to use the first bar for atmospheric pressure and the remaining 5bar for pressure, but when setting up a basic 0-100 psi sensor for fuel pressure, do you have to do the same?
Where are you mounting the fuel pressure sensor
Reply 0
Sep 13, 2014 | 08:08 PM
Quote: Where are you mounting the fuel pressure sensor
In the fuel rail.
Reply 0
Sep 14, 2014 | 04:41 AM
Quote: In the fuel rail.
Best to mount off rail if possible, sensors do not like the vibration.
Reply 0
Sep 14, 2014 | 06:47 AM
This. I have mine on the fuel rail and I get a bunch of variation in my logs.
Reply 0
Sep 14, 2014 | 10:57 AM
Good to know, ill hard mount the transistor on the firewall and use a ling to feed it.
Reply 0
Sep 14, 2014 | 12:38 PM
Gauge pressure and atmospheric pressure are not the same. MAP is atmospheric and fluid pressure, 9 times out of 10, is gauge pressure. IE no relation to atmosphere or is compensated upon being energized.
Reply 0
Subscribe
