Lite window for integra 98?
if you plan on running this in sfwd, i dont believe aftermarket windows are allowed.
on another note, fal makes a nice window. fitment is pretty good.
also might want to try speedglass. and cut your own window.
sounds like a hot rod or all motor car. just go full lexam , dont waste the money on fal. there are cheaper alternatives out there. Fal is good for street cars though that wanna save weight
Does KKC make lexan for hondas. i heard of people going to Home Depot and stuff and getting sheets of lexan and tracing and making templets to make their own windows.
NO Kens doesnt make them . him and Frank get them precut to the car from Percy's i think the place is. I know they fit awesome and are cheap as ****. also scratch proof. The crapo from lowes and what not will scratch to hi heaven
If you are going to buy your own Lexan, you want the Scratch Resistant kind. I believe it is called MR-10, but not positive.. And no, it isn't cheap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsvtec2.1liters »</TD></TR><TR><TD CLASS="quote">How and what would you use to cut it to you're template you made?</TD></TR></TABLE>
use a cardboard(oaktag works best) cut out of the window, trace it to the lexan. you might be able to use a small hand held air powerd saw to cut the lexan with. on the most recent car we built we laid the lexan over the window opening, cut it a bit bigger than we wanted, and trimmed it down to get a "perfect fit"
there is no sealent behind the lexan on my car, just black paint on the "underside/backside"
into either a window frame, which attaches to the body, or just drill holes through the window and body, put the bolt through than, tighten a nut on the backside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsvtec2.1liters »</TD></TR><TR><TD CLASS="quote">Ok this is a newb question, where does the rivets screw into besides the window it self?</TD></TR></TABLE>
rivets dont screw into anything. you need to drill holes into the window frame or make tabs and pop them in.
