jet fuel type a?
No you cant.......Jet a is and i qoute for you "Kerosene-type jet fuel (including Jet A and Jet A-1) has a carbon number distribution between about 8 and 16 carbon numbers; wide-cut or naphtha-type jet fuel (including Jet B), between about 5 and 15 carbon numbers.[2]"
Guest
Posts: n/a
I think you missed my sarcasm lol You can mix anything, whether it ends up homogeneous or heterogeneous it's still doable
And OP, don't even try it. Just keep the Q16 in it, it's made to run in a vehicle. We all have access to crack, but you don't see us all using it do ya?
I wouldn't even consider using it. Just use what your car was tuned on, in this case Q16. It's just not worth the risk of the potential damage you could do to your motor.
What about AV gas or aviation 100 leaded octane can I mix that w/ 93 unleaded octone? the car has not been tune on any race fuel yet but we are about to street tune one tonight and I just want to know if its safe to use this gas on say 15-20 psi of boost. Thank you all.
hey guys i was just wondering because i got 2 qts. of jet fuel, that's why i asked if i can used it , but if u think i need to stay t q16 i will definitely will
DO NOT MIX THE JET FUEL!!! It is more related to diesel than to gasoline. It is like a higher grade kerosene. Like someone else said, put it in your floor bullet heater and enjoy!
aviation gas is fine, if you wanna deal with the side-effects of leaded gas, but Jet fuel IS NOT A GASOLINE PRODUCT.
you'd be better off putting Coleman Lantern oil in the gas tank.
felipe69
Mar 21, 2008 08:53 PM
carbonall
51
Jan 6, 2006 01:19 PM
Do yourself a favor and stick with the q16. If you have a little extra Jet A, save it for your floor bullet heater
