Ignite E98 vs Ignite 114
Old Feb 8, 2012 | 09:09 AM
itspools's Avatar
Default Ignite E98 vs Ignite 114
I'm about to buy 4 barrels and thinking what I want to use. I'm ordering one barrel of 114 for a customer and my Evo buddy wants a barrel of E98. So I'm ordering 2 for myself, just want some opinions. (shipping if free from my local distributor on a 4 barrel order)
My setup is built SRT-4 engine (8.5:1 compression) with built/race ported head, S400 67mm with 1.25 housing, custom twin scroll manifold, FIC 2150s, Magna Fuel Pro Tuner 750 with sumped steel 95 Neon tank, -10 feed and -8 return. That's the jist of it.
I've done a ton of tuning on pump E85 and love it, but don't feel like dealing with the potential inconsistencies with the fuel for a primary track car.
So if you guys would post up your opinions that would be great. The usage of Ignite fuels seems to be heavy on this forum compared to the SRT-4 one.
Old Feb 8, 2012 | 10:00 AM
boosted hybrid's Avatar
Default Re: Ignite E98 vs Ignite 114
I have tuned/used both. The ignite yellow (e98) is pretty incredible stuff. I did not notice any real difference in power with the ignite red switch on my personal car. I would just personally buy the yellow and mix with unleaded gas if you have class rules to meet a e85 standard. On a Evo application I was in the 90% IDC range at 800 whp on ignite yellow with ID 2000cc's and dual 044's in parallel with 55 psi base pressure.
Old Feb 8, 2012 | 11:22 AM
itspools's Avatar
Good info Jeff!
I'm not gonna mix the fuel, I'm looking to keep it simple to an extent. I'm thinking Ignite 114 will be fine. I don't have any real class rules to fit into fuel wise. I'm mostly running IFO races and a local 1/8th mile series. I'll be at WCF in November.
Old Feb 8, 2012 | 12:08 PM
TURBOINTEGRA750's Avatar
my e98 yellow came in today cant wait to put it to use
Old Feb 8, 2012 | 12:50 PM
itspools's Avatar
See I'm considering the 114 primarily for it not being as rough on the injectors and pump. It's $60 a barrel cheaper for E98, but I'm not worried about $60 at this point. lol.
Old Feb 8, 2012 | 01:06 PM
SPOOLINmatt's Avatar
im probably going to go get a drum of e98 in march. who uses what to "make" their own e85. 93 oct? unleaded race fuel?
Old Feb 8, 2012 | 01:10 PM
i purchased mine made already. it has a oil in it already so it is not hard on injectors or motor. 55 gal 340 shipped
Old Feb 8, 2012 | 01:33 PM
tepid1's Avatar
^^^ From where?
Old Feb 8, 2012 | 02:02 PM
itspools's Avatar
I've got a local distributor that I can get the E98 a little cheaper then that for. I'm gonna call him tomorrow and place my order.
Old Feb 8, 2012 | 06:07 PM
PRO1's Avatar
Casey shhhhhh
Old Feb 8, 2012 | 06:39 PM
Originally Posted by PRO1
Casey shhhhhh
MY badd
Old Feb 8, 2012 | 07:54 PM
West Werks's Avatar
Wow, $6.18 per gallon... I should definitely get into the Ethanol game. I was planning on selling drums right at $300-305.00 per drum.
Old Feb 8, 2012 | 09:44 PM
aspsrt05's Avatar
Im that guy lol bump for nigel getting good info
Old Feb 8, 2012 | 10:51 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Is this a secret or can u pm me where u get it from? I need to order some ASAP
Old Feb 8, 2012 | 11:21 PM
V-SPEC 1's Avatar
the gas you mix it with will be any race gas does not matter what octane as long as its not pump gas. "Non Oxygenated fuel"
Old Feb 9, 2012 | 08:39 AM
darkhorizon's Avatar
I recently picked up 2 barrels of E98 (forget the brand, but its a race gas blend) off craigslist for $300.
Stuff is cheap up here in the corn belt... I figured about $3.00 a gallon for it in that deal, and about $3.30 a gallon if I buy it from a local distributor.
Old Feb 9, 2012 | 10:06 AM
itspools's Avatar
I ordered one barrel of 114 and 3 of the Yellow E98's.
Thanks guys!
Old Feb 10, 2012 | 11:40 AM
dsmfan95's Avatar
Thanks for the info. I'm running ID 2000cc's with a Magnafuel Pro Tuner pump, -10 feed and -6 return. I wanted to run E98 this season after having much success with pump E85 on a more mild setup.
Old Feb 10, 2012 | 12:14 PM
aspsrt05's Avatar
following that evo to piedmont was like smelling rotten popcorn lolol
Old Feb 11, 2012 | 04:58 AM
xenocron's Avatar
Mixing LEADED fuels with Ethanol can actually decrease the fuels effective octane...be careful mixing you own stuff together or you can do more harm than good....research research!
Old Feb 13, 2012 | 11:05 AM
While effective octane may drop... A large majority of people would benifit from the increased combustion speeds and flame front propogation characteristics.
I have been using leaded fuels to get a bit more power in the 60ft on my e85 turbo drag car sucesfully without hurting peak power.
Old Feb 13, 2012 | 01:03 PM
tony1's Avatar
Did you just say you use leaded fuel to get more power in the 60' on your E85 drag car?
Old Feb 13, 2012 | 01:13 PM
SO.GA_SI's Avatar
Tony, you have a lot of experience with this stuff. Any pros or cons between the 98 vs the 114, besides it hurting the 60ft lol
Old Feb 13, 2012 | 01:18 PM
tony1's Avatar
LOL. I haven't compared the two directly on the same car. I'd put money on the 60' times being pretty similar between the two though.
Old Feb 13, 2012 | 02:14 PM
GoldLudeRay's Avatar
ha lol tony.....i would be curious too see a e98vsc16vs114 test would be epic
