Whats up fellas. I was having a a conversation with a couple of race buddies on how to build a race motor for turbo, when some one said that he would build it really low compression and boost 40-50 psi. He said that he knows some one who has a race honda and that the car goes 8.6 and is making 800+ whp, but he is boosting 50+. I just think that is a bit much and that there isnt a need to boost that much to make only 800+. What do you guys think???
Marcos
Marcos
come on crisgo a little more specific.
ok lets see lower compression means you will have more cylinder volume, so there is more room for fuel and air, more fuel and more air means bigger explosion, witch will make more power than high compression as long as you have the fuel and turbo to keep up, buttttt! i like high compression you don't have as much volume but can run lower boost levels to make the same power its just alot harder on the rods pistions and crank
low compression and high boost
Lierley Fab
high compression high boost....alky dragster runs 12.5 with 55pounds of boost cams the key
Modified by fabman at 3:33 AM 11/10/2003
hes running a 12.5 with 50PSI ??? Isnt that slow
12:5:1 is what I think Pat was trying to get across.-pdang
i understand the low compression theory for a car on gas, on alcohol i think high compression would be the most optimal way to go.
HT's Biggest Loser
I wish i could run Alcohol. Like Miller stated, high compression is good for alky cars.. But for now, i would stick to a lower compression ratio if yer on gas.
one person says low compression and the other says high compression which one guys?
I know HP racing uses really low comp. motors and runs fast with them.
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx »</TD></TR><TR><TD CLASS="quote">I know HP racing uses really low comp. motors and runs fast with them.</TD></TR></TABLE>
They also have the Musclehead Mentality in that car... ...Big Block, Big Shot, Big Turbo.. they have no choice, hehe
actually the turbo isnt all that big. but it is a big motor, big shot.
lower compression help with traction also, turbo spools slower. Then pour it on when it hooks ehehehehehe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 »</TD></TR><TR><TD CLASS="quote">
doubt that very much </TD></TR></TABLE>
i know it is
i know it is
for a street car with around 500whp i still like the whole 9:1 compression with turbo. in like a b16 or b18. wount that help it last a little bit longer?
anyone car to elaborate with me on that?
