How to remove layer of rubber on slicks?
Old Jan 28, 2007 | 10:52 PM
Jockobo's Avatar
Default How to remove layer of rubber on slicks?
My slicks picked up a lot of rubber from the track over time and its causing it to not hook up anymore...how do i remove it? burning out doesnt seem to take enough off there's still a thick layer on there...
Old Jan 29, 2007 | 04:03 AM
sneakysneaky's Avatar
Default Re: How to remove layer of rubber on slicks? (Jockobo)
soak em in vht for a week it should brn off then.
Old Jan 30, 2007 | 08:20 AM
Xtream_V's Avatar
slicks can pick up rubber from the track? I didn't know that...how's it happen?
Old Jan 30, 2007 | 08:22 AM
miller's Avatar
Default Re: How to remove layer of rubber on slicks? (Xtream_V)
how many passes do you have on these slicks?
Old Jan 30, 2007 | 09:20 AM
SpeedDreamz.com's Avatar
Default Re: How to remove layer of rubber on slicks? (miller)
you sure it is not rubber peeling from your slicks?
Old Jan 30, 2007 | 11:56 PM
ImportMotorSpec's Avatar
Default Re: How to remove layer of rubber on slicks? (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">you sure it is not rubber peeling from your slicks?</TD></TR></TABLE>
x2.....I think it is time for some new slicks. Never seen a slick pick up rubber that would amount to traction loss. They like to pick up rocks and fling them everywhere...
Sounds like they are way worn, or you hit something sharp and are taking the layers apart. I had a tab on my fender well that wasn't bent up enough and hit a big bump at the end of US41 and took a nice chunk/slice out of a new set.
Old Jan 31, 2007 | 12:21 AM
Jockobo's Avatar
Default Re: How to remove layer of rubber on slicks? (ImportMotorSpec)
theyre about a year old and probably have over 100 passes on them but the indicators show there is a lot of meat left on them...i tried peeling off the rubber but only got half of it off and the part of the slick under the rubber is still sticky compared to the layer on top which is hard and cracking...took a lot of hours to get half the stuff off just wondering if there was a better way
Old Jan 31, 2007 | 03:27 AM
nsxmatt's Avatar
Try a burnout on a clean asphalt road. I know the rubber your talking about and I used to get it from really slick tracks. Mine would usually wear off after a few passes at a good track though.
Old Jan 31, 2007 | 05:43 AM
SPOOLINmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec &raquo;</TD></TR><TR><TD CLASS="quote">
... I had a tab on my fender well that wasn't bent up enough and hit a big bump at the end of US41 and took a nice chunk/slice out of a new set. </TD></TR></TABLE>
man have i been there and done that at my local track!!!
Old Jan 31, 2007 | 11:48 AM
Jockobo's Avatar
Default Re: How to remove layer of rubber on slicks? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Try a burnout on a clean asphalt road. I know the rubber your talking about and I used to get it from really slick tracks. Mine would usually wear off after a few passes at a good track though.</TD></TR></TABLE>
ooic...ill try that...yea it started building up from this one track i use to go to where they didnt let fwds go thru water and the track never really hooked up...rwd cars lost control all the time...
Old Jan 31, 2007 | 04:16 PM
JDMFerioEG9's Avatar
It happened to mine I just bought another set couldn't find a way to fix.
Old Jan 31, 2007 | 06:41 PM
qfast817's Avatar
Default Re: How to remove layer of rubber on slicks? (JDMFerioEG9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockobo &raquo;</TD></TR><TR><TD CLASS="quote">
ooic...ill try that...yea it started building up from this one track i use to go to where they didnt let fwds go thru water and the track never really hooked up...rwd cars lost control all the time...</TD></TR></TABLE>
i think i know that track well i would say bring it to me to put on my car
Astig
May 15, 2006 06:59 PM
95c1v1cs1
Sep 16, 2003 01:19 PM
