hondata datalogging frezzing
Old Jun 17, 2011 | 03:03 PM
bosted coupe's Avatar
Default hondata datalogging frezzing
s300
i took the whole msd 6al setup and ran a stock dizzy and the data logging still frezzing
anybody have these issues i run a hp laptop with windows 7
Old Jun 17, 2011 | 04:43 PM
NAH2B's Avatar
Default Re: hondata datalogging frezzing
mine use to do it all the time until i isolated the ecu from vibration.
Old Jun 17, 2011 | 05:48 PM
turbotypeR@SPEC's Avatar
25 Year Member
Are you turning it on by conditions? I had this problem once. I changed to a switch to turn it on and never had the problem again.
Old Jun 17, 2011 | 07:02 PM
SPOOLINmatt's Avatar
same here
Old Jun 17, 2011 | 07:51 PM
xohcef's Avatar
Originally Posted by SPOOLINmatt
same here
That makes 3 of us. Ill have to put mine on a switch. Heard of the cable running parallel to itself will also cause it to act weird.
Old Jun 17, 2011 | 08:00 PM
mrbsponge's Avatar
ohhh the s300 joys
this has been an issue for soooo long, like danny and matt said above, use the grounding switch and it will log for sure. I did every isolation trick, RF blocking trick, grounding trick I could and my car would just drop logging mid pull. put a switch on it and watched my dyno and my in car wideband and had at it.
on the other hand, I havent been able to make neptune drop any datalogging yet
Old Jun 18, 2011 | 09:44 AM
yeah i am just gonna put a switch on it screw it
dc4whore
Dec 12, 2006 11:59 AM
Unjockable
Mar 29, 2005 04:08 PM
seen4ever
Dec 15, 2004 04:24 PM
Quik Chris
Feb 18, 2003 05:39 AM
dariusz
Nov 27, 2002 03:38 PM
