Help Timing belt tuning
Old Jul 23, 2012 | 11:51 AM
Steeve_Civic's Avatar
Default Help Timing belt tuning
When pistons are to the top Dead Center with a comparator the ATI is 2 degree before the TDC and cams arrows are not in opposite.
I can adjust the cams as well.
My cams are Skunk 2 Pro Serie 1, what are the good tuning with these cams please?
Old Jul 23, 2012 | 11:52 AM
Dc4LsTeG's Avatar
EK9
Default Re: Help Timing belt tuning
Lol timing belt tuning. Don't touch anything take it to your tuner
Old Jul 23, 2012 | 12:08 PM
Okay I know that it is not the Belt that you tune lol!
Sorry for my technical English!
Old Jul 23, 2012 | 12:19 PM
2k.civic.si's Avatar
you need to degree the motor on pro cams to properly adjust the cams.
Old Jul 23, 2012 | 01:39 PM
OKAY thks, will take some picts tomorrow
Old Jul 23, 2012 | 02:43 PM
SPOOLINmatt's Avatar
i kinda got lost in the description, but i understand since it looks like you are from over seas.
Old Jul 24, 2012 | 06:54 AM
kyden's Avatar
degree them.
Old Jul 24, 2012 | 01:32 PM
jdm inc's Avatar
degree them in.
Old Jul 24, 2012 | 10:21 PM
h2.4's Avatar
its at tdc before the pulley says probibly because the block has been decked. use your true measurements for reference and you should set the pro 1's up from skunks recommeded centerlines for starters then tune from there as long as you've degreed the cams and your engine setup for safe advance and retard limits on this particular setup.
$amGD3
Jun 15, 2010 06:08 PM
lsteg94
Oct 14, 2007 07:59 PM
slimjimdanny
Apr 19, 2007 05:32 AM
MikeSarr_GSR
Dec 3, 2002 11:19 AM
JSIR
May 10, 2002 07:54 PM
