H2B transmissions at the track
Old Jul 28, 2011 | 01:03 PM
Hdeucedeuce's Avatar
Icon2 H2B transmissions at the track
Im just wondering how much time would you actually shave off by swapping your H22 motors tranny to a B series tranny. I know they have better ratios so i kinda wanna kno the difference from only and just swapping the trannys.
Old Jul 28, 2011 | 02:24 PM
ESP.net's Avatar
Default Re: H2B transmissions at the track
3-5 tenths has been documented with a GSR B trans
Old Jul 28, 2011 | 06:01 PM
h22apwrd95's Avatar
They seem to free up power as well. Less parasitic drag.
Old Jul 29, 2011 | 02:18 AM
zakura R's Avatar
Icon2 Re: H2B transmissions at the track
I will say putting new tranny, mid plate and mount and brakets and shave the block to clear axel it will take me 2.5 hours and u will see a big diference from h tranny to the b series one
Old Jul 29, 2011 | 02:59 AM
ZAK-H2B's Avatar
to me its much way better to shifting from H TO B tranny,
i did that to my setup and putting stock GSR tranny with Cuff, i droped my ET from 9.84 sec @234KM . to 9.61 sec @226KM. ((not ful pass))
Old Jul 29, 2011 | 07:03 AM
KStuned's Avatar
The main benefit is the availability of different ratios and the billet case. It depends on how much power you're making, tire size, etc. for what ratios you need. Please email me, we can figure out what will work best for you. As far as dropping 3-5 tenths, that could be the case if you have the wrong gearing and we get you into the correct gearing. There are lots of different gearing options in both the H and B series trans.
Old Jul 31, 2011 | 10:12 PM
thanks for the info. I admire that honda tried with the h motor tranny like dual cone synchros and some close gears but it sucks finding out that theyre glitchy and notchy to shift and the 1-2 gear rpm drop below vtec -_-. I kno someone with a stock gsr and i hate that he beats me at the tracks with my stock 5th gen h22 even when im making more power. i kno for a fact that the trannys are a big factor on why he beats me. That gave me the thought of mayb i could beat him if i swap my tranny for something like his
Old Aug 1, 2011 | 06:32 AM
2fastGSR's Avatar
King of the One Liners
Is this in a prelude ?
Old Aug 1, 2011 | 06:39 AM
turtleman321's Avatar
^^^That's what I was just thinking.
No h2b swaps for accords and preludes as of now
Old Aug 2, 2011 | 09:25 PM
yeah. h2b's are new to me. so they dont make kits for preludes?
Old Aug 2, 2011 | 10:02 PM
Krut's Avatar
Nope, EF/EG/DC/EK chassis only.
Old Aug 3, 2011 | 12:06 AM
bauergold's Avatar
You could still do it. Think outside the box and make it happen.
Old Aug 3, 2011 | 11:08 AM
ptftw's Avatar
i went from 13.1@105mph to 12.29@111mph. with a sub 220whp car @ 2225lbs. switching from M2b4 trans with 22" slicks to 98 spec ITR 4.7 final drive trans with 23" slicks.
Old Aug 3, 2011 | 12:48 PM
Krut's Avatar
You mind breaking down your slip? That's the exact setup I have and roughly the same power and weight. Curious how I nailed a 12.24 at such a low MPH (108MPH) When everyone else I see running low 12s are in the 110-112 range.
Old Aug 5, 2011 | 12:33 AM
holy ****! i love that tranny and its ratios tho haha
True. itll take alot of time and fabricating
my trap speed varies by how i launch and if i burn out alot then my speeds usually slower. also if i shift later in the revs it goes up. mayb you can compare his and your redlines
dgmorr
Jul 19, 2005 07:25 PM
dustrag
Jan 27, 2004 12:11 PM
jdmCivic925
Oct 20, 2003 11:07 PM
bearboy80
Aug 13, 2003 12:08 AM
