Fuel System Maintenance?
Old Nov 3, 2009 | 12:23 AM
noluckracing's Avatar
Default Fuel System Maintenance?
How long should you run aftermarket fuel pumps and regulators before you change them?
Old Nov 3, 2009 | 01:10 AM
tepid1's Avatar
Default Re: Fuel System Maintenance?
The only way to tell how long it will last is to find failure or to do periodic maintenance on your equipment and monitor wear. Some pumps/regulators are easy to take apart and inspect while others are not easy to take apart.
It's very dependant on the materials the component is made of, fuel used, environment it's used in and how hard you push the part.
Opinion time....
-Regulator should last forever unless the fuel eats it away. May need to replace seals every now and then....
-Pump (Bosch) should last a few seasons, again, dependant on all variables mentioned above....
-Pump (Weldon) I'd take it apart every season to check it out....
-Pump (Aeromotive) I'd just throw it away if you have one and save yourself the frustration.... lol
Old Nov 3, 2009 | 04:44 AM
SPOOLINmatt's Avatar
i sent my pump in for inspection, and they put new terminals on it, i ran the pump for 2.5 years...they tested it and it was perfect still.
Old Nov 3, 2009 | 07:00 AM
fmfkid250's Avatar
I have been running an A1000 for a few years now? Its even holding up for E-85?
Now that i posted this its going to **** the bed.
damnit.
Old Nov 3, 2009 | 09:54 AM
My stuff is 6yrs old is it time?Has any used the same pump and regulator that long?
Old Nov 3, 2009 | 10:01 AM
1992Si's Avatar
What pump do you have?
Call the manufacture and talk with them. If it's one of the big name brands, I'm sure they take a look at it for you.
Or we can tell you all kinds of things to mess with your mind.
Old Nov 3, 2009 | 10:05 AM
fmfkid250's Avatar
No way that ***** gotta be junk by now. The internal resistor diodes are thermocoupled by the biasing capacitor by now! after 4 years is when it starts!
J/K your ***** fine
Old Nov 3, 2009 | 10:43 AM
sgnlab's Avatar
We have a race car out here that has had an A1000 for about 5 years now and makes 800+ no issues.
Old Nov 7, 2009 | 10:17 PM
Does it race alot of events?
Old Nov 7, 2009 | 11:27 PM
V-SPEC 1's Avatar
How long should we change the filters on these pump? I have the eliminator Aeromotive pump and filters.
Old Nov 8, 2009 | 05:45 AM
CHECK THEM, the 10 micron is the one you gotta worry about. I usually take them out and blow through them to see how clogged they are, i always have a spare of one of those because i already lost an engine due to one getting dirty as hell.
EJ8CIVIC
Jul 5, 2015 12:07 PM
Vegas H22Prelude Si
Oct 13, 2008 08:10 AM
prelude994e
Sep 13, 2004 11:23 AM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
