Front End Limiting Straps ??
Old Oct 9, 2008 | 07:45 PM
Boosted_01 R's Avatar
Default Front End Limiting Straps ??
Ran my type R on the weekend and it worked pretty well on low boost, 11.8 @ 125MPH (1.95 60ft) Looking at run i can clearly see the front lifting a lot.
I know there's a good bit of imports out there running a front end limiting strap set-up. Is there a how to, on this? Or is there a kit i can buy? If there's parts i can buy and put together my self would be great. Prices?
Any input would be great guys. Thanks
BTW suspension is stock ITR shocks with coilovers. Just looking for a simple fix for now.
Modified by Boosted_01 R at 8:51 PM 10/9/2008
Old Oct 9, 2008 | 07:46 PM
2fastGSR's Avatar
King of the One Liners
Default Re: Front End Limiting Straps ?? (Boosted_01 R)
We used them before, cant say that we saw a difference.
Sounds like you need to set up the suspension a little better
Old Oct 9, 2008 | 07:55 PM
Axle's Avatar
The consensus is this: Limiting straps do help your ETs if you set them up right. However, whatever suspension problems you band-aid fix with the limiting straps can be permanently alleviated by using a good drag race suspension setup.
Lots of people run the limiting straps too tight which adversely affects the launch of the car because it pulls the wheels up too much.
Old Oct 9, 2008 | 10:23 PM
ExospeedAMcrx's Avatar
get better suspension with the proper sprign rate for drag racing. Safer, better solution to get those 60fts down.
also, what size slicks are you using and tire pressure?
Old Oct 10, 2008 | 06:04 AM
Default Re: Front End Limiting Straps ?? (ExospeedAMcrx)
Still in the testing stages. Had problems building boost so i had to put back air in the tires to 15psi, no burn out(yes i know it should be at 6psi-8psi) to get it spinning off the line, ended up using MSD 2-step. Its M/T 24.5/8/15 on USDM ITR wheels. Would be happy with a 1.6 ft eventually, what drag suspension would you say is best.
Old Oct 10, 2008 | 06:08 AM
ReDemoN's Avatar
DixielandImports Please
Omni, Blox, skunk 2 makes a spring kit
Old Oct 10, 2008 | 06:35 AM
Well there you go. the 1.9 is because of the tire pressure. work on that first. no need to get suspension yet.
Old Oct 10, 2008 | 10:23 AM
AllMotorRandy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Well there you go. the 1.9 is because of the tire pressure. work on that first. no need to get suspension yet.</TD></TR></TABLE>
dont forget will that the other way to get 60fts down is by also utilizing a longer 1st gear
Old Oct 10, 2008 | 10:33 AM
What do you guys think about a stiffer rear spring, currently its at 350LB. What do you guys think about a 800LB or 1000LB on stock type R shocks. Would it be too bouncy, due to the stock ITR dampening ?
jv88_dc2
Suspension & Brakes
Sep 4, 2010 04:45 PM
k279
28
Jun 2, 2004 10:17 AM
Kendall
Feb 5, 2004 05:54 PM
turbolshatch
Jul 12, 2003 03:28 PM
Flux
Oct 23, 2001 09:38 AM
