electric water pump
Old Jan 21, 2004 | 05:54 AM
lovitalracer's Avatar
Default electric water pump
I'm getting ready to install my Golden eagle Electric water pump .
A few questions . Upper or lower hose ? Keep the Thermosat or lose it ?
How much horse power gain ? Post some pics if possible !
Thanks
Old Jan 21, 2004 | 06:27 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: electric water pump (lovitalracer)
Lower Hose, get rid of the thermostat..
Old Jan 21, 2004 | 06:38 AM
Default Re: electric water pump (SIXTYdashONE)
Thanks man !
One more question ,, well this effect the Vtec ingauging .?
Cause on the normal cars , if the engine is not warm the
Vtec will not kick in .
Old Jan 21, 2004 | 06:44 AM
HT's Biggest Loser
depends what management your running.. I run DFI with an MSD rpm activated switch, so vtec always comes on.
Old Jan 21, 2004 | 06:46 AM
That's right , I'm on speed pro with the switch too .. Thanks again
Old Jan 21, 2004 | 06:50 AM
HT's Biggest Loser
Your in the clear Lo'
Old Jan 21, 2004 | 11:58 AM
MaxBoost's Avatar
New User
Any possibility of adapting an electric water pump so that it works properly in a street car?? Any way of retaining thermostat? Any way of making pump increase gph per rpm.
Old Jan 21, 2004 | 12:08 PM
dkim48's Avatar
Default Re: electric water pump (MaxBoost)
the meziere pump's instructions state to drill two small holes in the stock thermostat...my buddies got one in his car and it runs too cold...and he followed the instructions...
he's thinking of putting it on a switch but that will be pain in the ***...maybe something to the stock sender??
Old Jan 21, 2004 | 12:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Your in the clear Lo'</TD></TR></TABLE>
I have a full race car , do I just hook it up to on all the time as soon as I start the car or should I wait for a few minute ?
Old Jan 21, 2004 | 01:56 PM
FULLTHROTTLE's Avatar
I plan on running mine during a run and between runs to cool down. (also a full race car)
Old Jan 21, 2004 | 02:05 PM
HT's Biggest Loser
I have mine on a toggle switch, but its ran 100% of the time the car is running...
Old Jan 21, 2004 | 03:38 PM
Adam F's Avatar
We had ours on a switch, but now I think it will run when the motor is running. Here are a few pics
Old Jan 21, 2004 | 05:08 PM
ninesecteg's Avatar
what speedpro do you have. seq. or b2b? if its bank to bank you could set it up using the fan control. when the engine reaches a certain temp a relay can turn on the pump and fan.
Old Jan 21, 2004 | 05:17 PM
tony1's Avatar
Default Re: electric water pump (ninesecteg)
You have to be careful with running the engine with the pump off. The water won't circulate and you will create hot spots around the exhaust valves, which isn't good. That's what the guy at Mezierre told me when we were running kenny's car with the pump off to get it to warm up quicker. I don't know...we never had a problem?
Old Jan 21, 2004 | 06:10 PM
evilxkid's Avatar
Default Re: electric water pump (tony1)
i ran the maziers pump with the two holes in the thermostat for along time in my daily driver and it was fine.
Old Jan 22, 2004 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecteg &raquo;</TD></TR><TR><TD CLASS="quote">what speedpro do you have. seq. or b2b? if its bank to bank you could set it up using the fan control. when the engine reaches a certain temp a relay can turn on the pump and fan.</TD></TR></TABLE>
That 's the one I have , and yes I have that option but I guess I will hook it to a switch and turn it on with all the other stuff , all at once .
Old Jan 25, 2004 | 09:14 PM
I have the Golden Eagle unit now, I built a bracket for it today. After I install it tomorrow I will take pics. Just to keep the thread up and give a few other install points.
Old Jan 26, 2004 | 02:18 PM
TrueNorthStar's Avatar
Default Re: electric water pump (FULLTHROTTLE)
You could try this:
Here is a quote from the website:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by website &raquo;</TD></TR><TR><TD CLASS="quote">Technical Specifications:
Input Voltage 12V DC to 14.5V DV
Output Voltage
3V to 12V
Max. Current
7.5A
Operating Temperature
-20 C to 60 C (-5 F to 140 F)
Controller Type
Circuit Board with Microprocessor and Programmable Chip
Sensor Type
Thermal Coolant Sensor in water-proof housing
Controller Weight
300 g (10 oz)
Dimensions
95 mm (H) x 65 mm (W) x 50 mm (D) 3-3/4" (H) x 2-9/16" (W) x 2" (D)
I think something like this would work well.
Here is a link to the site you can buy it from: http://www.spatechnique.com/de...P8010
widewhite
Jun 20, 2015 07:39 AM
ranta18
Nov 12, 2009 08:04 AM
cyrix12
10
Dec 24, 2005 07:29 AM
full Circling
Jun 30, 2005 02:37 AM
takeheed
Dec 4, 2002 06:28 AM
