Drag time estimater
Old Dec 11, 2003 | 08:29 AM
x00gsr's Avatar
Default Drag time estimater
Check this site out. Pretty cool. http://greatlakesdragaway.com/analyzer.htm
Old Dec 11, 2003 | 08:35 AM
PM-Performance's Avatar
Default Re: Drag time estimater (x00gsr)
its actually kinda accurate.
when i pulled a 12.80 i weighed in about 2550 or so and was off tune so was only like 240-250whp and tihs came up pretty on .
Old Dec 11, 2003 | 10:01 AM
poorguy's Avatar
Default Re: Drag time estimater (itr206)
is the calculated hp flywheel or wheel hp?
Old Dec 11, 2003 | 10:23 AM
SadisticRacing's Avatar
Default Re: Drag time estimater (poorguy)
It looks to be at the wheels from the numbers I got.
Old Dec 11, 2003 | 10:38 AM
TMKsAllMotorEg6's Avatar
Default Re: Drag time estimater (SadisticRacing)
yeah its to the wheels. i think its acurate
Old Dec 11, 2003 | 10:58 AM
GreenR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorguy &raquo;</TD></TR><TR><TD CLASS="quote">is the calculated hp flywheel or wheel hp?</TD></TR></TABLE>
It will tell you both if you use the last hp calculator.
Old Dec 11, 2003 | 11:14 AM
jinxproof99's Avatar
New User
Default Re: Drag time estimater (GreenR)
NOT accurate at all for fwd cars. says i could go 9.80's @ 137 mph with 510 to the wheels in a 2500 lb car. yeah, if i was rwd.
Old Dec 11, 2003 | 11:15 AM
D16OnTop's Avatar
preaty acurate
Old Dec 11, 2003 | 11:16 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Drag time estimater (jinxproof99)
yah, said my car should do 9.55 with my weight and mph. But it did say that with my 2475 and 141 traps, that i was makin 540, which maybe accurate, i dunno
Old Dec 11, 2003 | 11:27 AM
daygo_beanR's Avatar
From: san diego, miami, rosarito mx, rio de janeiro, guangdong
Default Re: Drag time estimater (SIXTYdashONE)
186.55398651234728 HP from my EF-- 2320 pounds and 101 trap speed stock block b16, nice
Old Dec 11, 2003 | 06:19 PM
TurboDANDEE's Avatar
Default Re: Drag time estimater (daygo_******)
Estimated Horsepower might be accurate, but the dame Estimated 1/4 E.T. sure is way off It says i should be running 1/2 a second faster
Old Dec 11, 2003 | 06:41 PM
Drew Peacock's Avatar
Default Re: Drag time estimater (TurboDANDEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">Estimated Horsepower might be accurate, but the dame Estimated 1/4 E.T. sure is way off It says i should be running 1/2 a second faster </TD></TR></TABLE> And that would work out that way how? Its reasonably accurate it say's with 215whp and 2300lb car I'd do 12.8 that would be about right for an allmotor car or FI on slicks hooking up well.
Old Dec 11, 2003 | 07:16 PM
Default Re: Drag time estimater (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote"> And that would work out that way how? Its reasonably accurate it say's with 215whp and 2300lb car I'd do 12.8 that would be about right for an allmotor car or FI on slicks hooking up well.</TD></TR></TABLE>
Well it's wrong for me, the same goes for Jinx and Sixty Cent
Old Dec 11, 2003 | 10:18 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote"> ......Its reasonably accurate it say's with 215whp and 2300lb car I'd do 12.8 that would be about right for an allmotor car.......... </TD></TR></TABLE>
no, actually thats pretty bad. with 215 to the wheels weighting 2300 lbs, in an allmotor cars, you would be running 12.20 easy. maybe 12.10. the calculator is as off as all the other ones on the net.
for the record, my old NA car went 12.40's weighting 2300 and pulled like 205 on the dynojet.
Old Dec 11, 2003 | 10:42 PM
we did 12.2's @ 111 mph on a 92 hb weighing 2400 lbs. i put out around 210-215 whp.
Old Dec 12, 2003 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 &raquo;</TD></TR><TR><TD CLASS="quote">
for the record, my old NA car went 12.40's weighting 2300 and pulled like 205 on the dynojet.</TD></TR></TABLE>Oh ok I thought they sounded reasonable, what about the times for FI since thats what my car is. Think it could hit a high 12? 215whp/200TQ 2350lbs...
Old Dec 12, 2003 | 05:32 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
this **** is way off for me
i put in 2500lbs with me in the car (91 gutted integra/i weigh 215lbs.) with I/H/E on the stock b18a. and i run a 15.2.........says i should have 182hp at the fly. BULLSHIT. i'd be lucky to be pushing anywhere near 150
Your integra weighs about 2500 pounds and can complete a 1/4 mile in about 15.2 seconds. That means that you've got about 140.70 HP at the wheels, and about 182.91 HP at the flywheel. &lt;&lt;&lt;&lt;&lt;total BS
Old Dec 13, 2003 | 08:02 AM
DIRep972's Avatar
Smarter than you
These things are never accurate for fwd vehicles, but it actually wasn't that far off for me. w/ 109 trap @ 2620lbs it says I made 265whp... which is pretty much dead on for when I ran 12.89 @ 109.. Then for ET it estimated it thinks I will run a 12.50 @ that power/weight.. Definitly possible if i ran it on slicks.
Old Dec 13, 2003 | 08:45 AM
espanol's Avatar
Default Re: Drag time estimater (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">These things are never accurate for fwd vehicles, but it actually wasn't that far off for me. w/ 109 trap @ 2620lbs it says I made 265whp... which is pretty much dead on for when I ran 12.89 @ 109.. Then for ET it estimated it thinks I will run a 12.50 @ that power/weight.. Definitly possible if i ran it on slicks. </TD></TR></TABLE>
according to that thing i only need 400hp to run a 10.6 at 126..yeAH RIGHT!
Old Dec 13, 2003 | 10:36 AM
ECKOTYPER's Avatar
HEHE THIS THING IS A PRETTY COOL THING TO MESS AROUND WITH BUT I WOULDNT TRUST THIS JUST LIKE I WOULDNT EVEN TRUST A G TECH, ONLY WAY TO REALLY CALCULATE IS TO STAGE, LET THE LIGHTS DROP, AND GO FAST!
Old Dec 13, 2003 | 12:22 PM
kid-honda's Avatar
Seems pretty good to me, atleast for free.
For a few seconds of your time you cant expect perfect answers.
Old Dec 14, 2003 | 02:39 PM
baxter04's Avatar
pretty good in our case. Thanks!
Old Dec 14, 2003 | 08:13 PM
GirlieRacer7o2's Avatar
pretty accurate. :-)
Old Dec 15, 2003 | 07:54 AM
v4lu3s's Avatar
RTFM
considering that its calculations are for rwd cars its pretty accurate for me. says that i should be in the 13.7@99 range if i am making 175-180 hp and weigh 2300lbs....
my current best is a 13.7@99.96 with a stock h22a in a gutted civic and my 220lbs in it.
Old Dec 15, 2003 | 08:51 AM
b18cx's Avatar
Default Re: (v4lu3s)
PLEASE dont flame me for this.
Maybe its showing you that you need to learn to drive your car????
Was pretty accurate for me.
I think I'm gonna get hammered for this one
