drag suspension setup
Old Mar 7, 2013 | 12:56 PM
HONDATAD16's Avatar
Default drag suspension setup
Hey first post on your forum. I recently bought a 95 eg with d16. I wanted to set up car for street/strip. Car has rebuilt d16 with sleeved block, eagle rods, wiesco pistons,272-2 cam, edelbrock x intake,70mm throttle body, golden eagle fuel rail,id 1000cc injectors,hondata 300s, precision 6031 turbo, 38mm precision waste gate, spoolin performance turbo manifold. I need to have car tuned. My question is whats the best setup for drag racing and daily driver. i can deal with a firm ride. Do I need traction bar? Car is curently lowered with springs only, I want to replace with coilovers. Also car has rsx exhaust from down pipe back with stock muffler. I feel this is hurting performance from excessive back pressure. Thanks in advance.
Old Mar 7, 2013 | 07:39 PM
Weaversautomoti's Avatar
Default Re: drag suspension setup
personally i think a set of blox full bodied drag race coil overs will be just fine for ya
Old Mar 8, 2013 | 02:54 AM
jdm inc's Avatar
http://www.ipgparts.com/store/Progre...ing-Rates.html
Check those out!
Old Mar 8, 2013 | 11:09 AM
92_DB2's Avatar
Progress all the way
Old Mar 8, 2013 | 11:58 AM
crxtc_vtec's Avatar
Im running function and form type 1's
Old Mar 8, 2013 | 01:06 PM
HONDATAD16's Avatar
Thanks everyone for info. I posted engine setup to help with selection of coilovers. Car also has act clutch and street light flywheel and dsport engine mounts. Also what axels for this car? Are driveshaft shop axels worth the money at my hp? I want car to hook still spinning at 60-80 with street tires and obx lsd. I know I need boost by gear control, whats best brand boost controler? have manual boost control now? Thanks again great forum.
Old Mar 8, 2013 | 01:33 PM
Progress is great its what ill be running on my drag car this summer. Just do whats in your budget if money isnt an issue then go with strange or progress but since it will be street driven then id just go gmforblox or function and forms
Old Mar 8, 2013 | 03:00 PM
PhilStubbs's Avatar
If you are on a tight budget, I have a mix of eBay coil overs and a set of brand new skunk2 sport shocks. My front springs are 350# and the rears are 650#. That got me a 1.7 60' on 23" slicks, open diff with a 270-ish HP turbo EF. You can order springs cheap from speedway motors to dial it in.
Not knocking the higher dollar stuff, just showing another option
Old Mar 8, 2013 | 03:06 PM
mike93eh2's Avatar
PIC Performance all the way!
Old Mar 9, 2013 | 09:59 AM
SR20S13's Avatar
I was always under the impression that you needed a stiff springs in the rear if these cars and it made sense, but after some research I've seen that a lot of top racers use a softer spring on the rear to let the car squat a little on launch and play with the 60ft with adjusting the shock settings... At least that's what I'm going to try lol
Old Mar 9, 2013 | 03:07 PM
PhilStubbs's Avatar
Springs are cheap, give it a shop
Old Mar 10, 2013 | 04:53 PM
mike93eh2's Avatar
you dont want it to "squat" or the weight to transfer to the rear. look at all the hot rod cars that run wheelie bars..what do you think those wheelie bars do?
Old Mar 10, 2013 | 06:58 PM
SR20S13's Avatar
okay you can believe what you want to believe and i'll believe what I want to believe, i've done my research and i'm sticking to it.
Old Mar 10, 2013 | 08:24 PM
ThePunisherPnc's Avatar
skunk 2 pro does me justice
JDM809
Suspension & Brakes
Jul 11, 2011 12:18 PM
Cvekiux
Nov 24, 2008 04:33 AM
AllMotorRandy
Mar 30, 2005 02:05 PM
mamaboy
Oct 24, 2003 05:14 AM
