Drag radials help..??
Old Nov 12, 2004 | 11:06 PM
akio74's Avatar
Default Drag radials help..??
hey im looking for sum steelies and drag radials. ive found a couple at discount tire... (15x6.5)
http://discounttire.com/dtc/fi...w=6.5 (top 2)
then the tires BFGoodrich Gforce Drag radials...
if you click the size and spec sheet, im lookin at the MSPN # 98003 or 49256....225 or 205 respectivaly.
http://www.bfgoodrichtires.com...l.jsp
any comments suggestions or reasons i should NOt go with these? any reason not to go with the 225 over the 205??
thanks
Old Nov 13, 2004 | 01:57 PM
JerseySiPOS's Avatar
Default Re: Drag radials help..?? (akio74)
this was my thread that i asked the same thing pretty much. there are some pretty long posts, but good info on tire diameter and width and what is a perfect size for your setup.
https://honda-tech.com/zerothread?id=1049430
a 225/50/15 is taller than a 205/50/15.
go to this tire calculator. i would run a tire at 22.5" or more in diameter but not quite 23".
i just put on a set of Nitto Drag R's in 205/55/14s today on a set of 96 civic steelies.
karmadhi
May 24, 2008 07:26 PM
95ejjj
Jun 9, 2005 05:58 AM
PIFFSTAR
Mar 23, 2005 05:58 PM
vtecmike1
Apr 13, 2004 12:32 PM
LsTurbo91
Jan 19, 2002 03:39 PM
