Drag Lug nuts
What are you guys using for lug nuts? Ive had some steel ext lug nuts for a while and they are getting beat up. I cant remember what they are.
I looked at these
http://www.evasivemotorsports.com/mm...tegory_Code=L1
I have exospeed star8's...i know they work with the shanked with washer type lug nuts ....where can i get those......whats the better conical type to use. not really a fan of the aluminum lug nuts.
I looked at these
I use the shanked type ones for my welds.
got mine from summit racing.
http://www.summitracing.com/parts/WLD-601-1452/
absolutely hated using those blox/aluminum lug nuts. they strip way too easily if you have to remove the wheels often
i use the shank style on my bogarts
friend ordered his from IPG and they sent the right size since we had no idea which one to order
blox extended cromoly open ends, I used aluminum lug nuts before and and after some passes and burnouts on slicks, I had to use a dremel to remove 2 of them, they got so hot they just twist when I tried to remove them.
I went with these to retain using a typical 19mm or 3/4" 6pt socket to remove the lug nuts without a tool that could be hard to find if we were away from home.
They're steel and don't have problems galling. Smack them with an impact all day if you want.
https://www.pegasusautoracing.com/pr...asp?RecID=5686
I have had my chromoly lugs for a couple a yrs.
Been taken Off 20-30 times easy... Still near Perfect
