Different sound from 2 step ?
why is that some 2 step sounds different. ie cuhna on the 2 step sound like a top fuel dragster @ idle and Titan motorsports on the 2 step sounds like when you hit rev limiter?
with my 2 step at launch it sounds like rev limiter but at redline it just sets at 7000 rpm because i have my uber redline set at 8500 rpm. so maybe they have something like that set-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">u guys ever heard laskey's 2 step? cleanest 2 step ever.</TD></TR></TABLE>
anyone have a video of this?
the biggest difference in sound is caused by how much rpm the motor drops and then restarts if it drops 500 rpm at the 2 step and comes back up it makes alot different sound then when it only drops 200rpm,
I think the coolest sounding 2-step was Chris Rado's on the "Ghetto-Glider". That thing was nasty, flames and all. I remember shooting event coverage and feeling pressure against my chest while he was on the staging line. Tres cool.
Garys sounded cool as well. Every engine sounds different as stated in previous posts due to modifications and tuning. My S13 sounds "different" on a 2-step.
just remember,all that cool popping and banging,while on the 2 step is reaking havoc on a turbo!!!!......
for guys running anti-lag be even more careful...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL.RODD »</TD></TR><TR><TD CLASS="quote">just remember,all that cool popping and banging,while on the 2 step is reaking havoc on a turbo!!!!......
Is there a better way to build boost?
</TD></TR></TABLE>Is there a better way to build boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv »</TD></TR><TR><TD CLASS="quote">
Is there a better way to build boost?</TD></TR></TABLE>
Nope, antilagging is the only way to build boost on launches. Some 2 steps can build small amounts of boost but nothing close to antilag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports »</TD></TR><TR><TD CLASS="quote">
Nope, antilagging is the only way to build boost on launches. Some 2 steps can build small amounts of boost but nothing close to antilag.</TD></TR></TABLE>
Well all I used was a MSD 3step rev limiter and messed with timing. Was able to make well over 10lbs, all I needed on 26's!!! Shot flames and popped your eardrums........ Retard timing = more boost
If you pull timing the in the map just make sure it doesn't ever pass back through that section down the run. We've done that before, lol!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">If you pull timing the in the map just make sure it doesn't ever pass back through that section down the run. We've done that before, lol!</TD></TR></TABLE>
You are absolutely correct. But I never saw 10psi at 7000rpm thorughout the run. At that point your usually over 30psi
