D2B Addapter Plate
Old Sep 26, 2009 | 12:51 PM
  #26
Cotterpin-PFI's Avatar
Default Re: D2B Addapter Plate
Ive tried si,dx,hf and even the std 4spd the dx,si trannys arent very different the hf is way to long and before i put the b-series the 4spd held up the best and ran a 10.5 @150 on it but 1st to 2nd always fell out of boost but im probably making close to 700hp on the nitrous so it didnt really matter.
Old Sep 26, 2009 | 12:52 PM
  #27
Originally Posted by AJxr
so in the first picture, the top left bell housing bolt above the starter lines up perfect?
Yea the bolt above the starter lines up then just go from there figuring out how to make the rest line up.
Old Sep 26, 2009 | 12:57 PM
  #28
Originally Posted by PhilStubbs
in for the pics. i have wanted to do this for a while, but never thought of making it bolt up without a plate. does a b series clutch bolt up to a d series flywheel or was there some drilling and taping going on there too?
I have a stock d-series flywheel turned down for my old comp clutch b-series twin disc to bolt up to i was using it with d-series twin disc plates and just switched it back to the b-series ones.A b-series pressure plate wont bolt to a sohc flywheel but im trying to find a disc that will work with a d-series presure plate and flywheel.
Old Sep 26, 2009 | 01:04 PM
  #29
jjspec's Avatar
That may be a good start for a dowel location.
Old Sep 26, 2009 | 03:50 PM
  #30
Martian's Avatar
Maybe comp clutch will be nice and make their stage 4 Dseries with a B series spline for us.
Old Sep 26, 2009 | 04:39 PM
  #31
jjspec's Avatar
Should not be an issue.
Old Sep 26, 2009 | 04:53 PM
  #32
Comp made me my sohc twin disc plates with no problem so im sure they can make.
Old Sep 26, 2009 | 06:18 PM
  #33
AJxr's Avatar
wait a sec, wheres the pics of the car/turbo setup!
Old Sep 26, 2009 | 07:04 PM
  #34
Martian's Avatar
http://www.youtube.com/watch?v=9BI620CRF54
Green CRX is what you're looking for.
Old Sep 26, 2009 | 07:20 PM
  #35
Its the flat green crx i raced my brothers eg hatch fully built ls-vtec that makes 640hp againt my sohc 580hp no nitrous.Ill get some good pics of the car tomorrow.
http://www.youtube.com/watch?v=dOmKY-NVafk
Old Sep 26, 2009 | 07:39 PM
  #36
b18vtec's Avatar
What about the rear bracket? if the whole motor moves over about an inch, then the rear bracket will not line up?
Old Sep 26, 2009 | 07:50 PM
  #37
Which bracket?
Old Sep 27, 2009 | 04:15 AM
  #38
Boosted-EH-804's Avatar
This is great gives me some hope. I have all winter to get it right.
Old Sep 27, 2009 | 05:18 AM
  #39
Swipe'd's Avatar
Bummp
Old Sep 27, 2009 | 06:43 AM
  #40
beasty=eg's Avatar
i want to see more pics... 10sec D's all day now
Old Sep 27, 2009 | 08:13 PM
  #41
mike93eh2's Avatar
i still dont understand what clutch disc you used that fits the d-series flywheel and b-series mainshaft...
Old Sep 27, 2009 | 09:15 PM
  #42
Martian's Avatar
Its a twin disc specially made to fit the d series pressure plate, but has a B series hub.
Old Sep 28, 2009 | 03:34 AM
  #43
Im going to try with a regular clutch and see about getting the disc that he has. But he said he put his B series disc back in. Was there any reason why you just put the B disc back in
Old Sep 28, 2009 | 07:05 AM
  #44
All it is is a Comp Clutch B-series twin disc with a STOCK d-series flywheel MACHINED down to look just like the b-series twin disc flywheel
Old Sep 28, 2009 | 07:10 AM
  #45
I had the twin disc disc's made for my sohc tranny with the sohc spline.I had to change the discs when i put the b-series tranny on as they are different spline then d-series
Old Sep 28, 2009 | 07:13 AM
  #46
ReDemoN's Avatar
DixielandImports Please
Wow.
I just found a B series trans the other day when I was cleaning.
Hmm might have to try this.
Old Sep 28, 2009 | 05:14 PM
  #47
AJxr's Avatar
i know the green crx but ive never seen the engine bay. the only pic in the vid is a cracked block.
Old Sep 28, 2009 | 05:35 PM
  #48
base-op.1320's Avatar
Originally Posted by ReDemoN
Wow.
That must have been one dirty garage to just find a b series trans when cleaning. lol
Old Sep 28, 2009 | 05:43 PM
  #49
Yey I got that part guess I did not relay it very well
Old Sep 28, 2009 | 07:07 PM
  #50
Martian's Avatar
Not really much to see that you havn't already seen. Sleeved D, vtec head, turbo, air to water intercooler, shot of spray. Thats it!.
