crank trigger question?
Subscribe
Feb 20, 2007 | 05:32 AM
  #26
Re: (wHOAlly)
I am running the r5671a-10 plugs,a oldschool 6al ign.box stock dizzy,msd cap and stock rotor, curious how those plugs might be a problem,because thats a new one to me please explain?and what plug do you or anyone fo that matter suggest?
Reply 0
Feb 20, 2007 | 06:37 AM
  #27
Re: (BlownHatch)
i think there is an article on MSD's website that explains it
Reply 0
Feb 20, 2007 | 06:40 AM
  #28
Re: (JDogg)
ive tried all differnt kinds of spark plugs. more often than not the stock distributors suck with AEM.
Reply 0
Feb 20, 2007 | 06:55 AM
  #29
Re: (Turbo-charged)
nuff said
Reply 0
Feb 20, 2007 | 07:05 AM
  #30
Re: (Turbo-charged)
yeah, i have never seen spark plugs have an effect on the pickups in the distributor
Reply 0
Feb 20, 2007 | 08:02 AM
  #31
Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">ive tried all differnt kinds of spark plugs. more often than not the stock distributors suck with AEM.</TD></TR></TABLE>
Stock distributors cause problems with most ecu's...
I have run them without issues but i had to modify the teeth inside.
If using the AEM i would just use the T1 trigger and get it over with.
Why gamble when you know the T1 trigger works flawlessly every time..
Reply 0
Feb 20, 2007 | 11:38 AM
  #32
Re: (Enzo-Racing)
yeah im gonna go with the t1 trigger kit
Reply 0
Feb 21, 2007 | 05:04 AM
  #33
Re: (BlownHatch)
at what point does the stock dist. give you guys problems? high HP? high RPM? what?
Im just wondering because I havent had any problems with the stock dist & my 1030U.
(knock on wood)
But Im not making quite as much power as most of you guys...
just looking for more info as to what the actual problem is i guess...
Reply 0
Feb 21, 2007 | 05:07 AM
  #34
Re: (ykracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ykracing &raquo;</TD></TR><TR><TD CLASS="quote">at what point does the stock dist. give you guys problems? high HP? high RPM? what?
(knock on wood)
just looking for more info as to what the actual problem is i guess...</TD></TR></TABLE>
my oem dist was giving alot of error codes @ idle even, it would shut the car off because of it... i dont even want to know what it would have done had i tried to push the envelope with a dist giving off "errors" to the ecu... probably all kinds of misfiring/BS
Reply 0
Feb 21, 2007 | 05:11 AM
  #35
Re: (ykracing)
if you havnt had any problems you just have one of the like 20 distributors ever made that just "work". they are 100% hit or miss from what i have seen. ive only seen one so far that worked well for a while and then eventually took a crap.
Reply 0
Feb 21, 2007 | 08:44 AM
  #36
Re: (ykracing)
6000 up under boost and it's not spark plugs got away form stock dis mis went away
Reply 0
Feb 21, 2007 | 12:13 PM
  #37
Re: (fast is fun)
i am having misfires down low to i didn't have them on the dyno put the car on the trailor came home took it off and having issues up to about 5500rpm then car takes off like a rocket till like 9000rpm then it just kinda hits a brick wall so im hoping that my dizzy and no trigger kit are causing the lower rpm problems as well because it did not do this on the dyno and instantly when i took the car off the trailor it did but the last dyno pull it started to get shaddy way up top so im hoping this is the cause
Reply 0
Feb 21, 2007 | 06:49 PM
  #38
Re: (BlownHatch)
Just wanted to add that I saw a 3d model of Tony's new trigger bracket that he will be making soon, and it is even nicer than the last one!
Now if I could only afford a "great" EMS to use it with, I'd order one..
Reply 0
Feb 21, 2007 | 06:59 PM
  #39
Re: (locash)
Reply 0
Feb 21, 2007 | 07:23 PM
  #40
Re: (tony1)
yep, the T1 v.2 trigger kit
Reply 0
Feb 22, 2007 | 10:54 AM
  #41
Re: (SpeedDreamz.com)
Its actually v.3 because I have v.1 and I am the only one that has v.1. I still remember when tony first made he said, you now have the best looking crank trigger around. lol
Reply 0
Feb 22, 2007 | 11:13 AM
  #42
Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Its actually v.3 because I have v.1 and I am the only one that has v.1. I still remember when tony first made he said, you now have the best looking crank trigger around. lol</TD></TR></TABLE>
thats cute
Reply 0
Feb 22, 2007 | 11:16 AM
  #43
Re: (BlownHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownHatch &raquo;</TD></TR><TR><TD CLASS="quote">i am having misfires down low to i didn't have them on the dyno put the car on the trailor came home took it off and having issues up to about 5500rpm then car takes off like a rocket till like 9000rpm then it just kinda hits a brick wall so im hoping that my dizzy and no trigger kit are causing the lower rpm problems as well because it did not do this on the dyno and instantly when i took the car off the trailor it did but the last dyno pull it started to get shaddy way up top so im hoping this is the cause </TD></TR></TABLE>
what ems do you have?? if you have aem, log t2per (or t4per if you have a 1010) and cam-crank, if you see those 2 break up when the car breaks up then the dizzy is the problem
Reply 0
Subscribe
