Corner Balance
Old Mar 24, 2013 | 11:38 AM
Steeve_Civic's Avatar
Default Corner Balance
Could you help me to corner balance my car?
What are good specs?
I heard about 70% front are 30%?
Is cross weight (Front Right and Rear left) important?
Here is my car balanced below with driver inside
Old Mar 24, 2013 | 11:44 AM
redboost10's Avatar
Default Re: Corner Balance
Damn! What car is this?
All that really matters is front right vs front left
Old Mar 24, 2013 | 11:47 AM
SR20S13's Avatar
do some searching I know this has been covered before, that's the great thing about honda-tech if you look hard enough someone has asked this before or wrote about it before. But from what I can remember you want the cross weight to be the same, which and the front needs to be as close to the same as each other.
Old Mar 24, 2013 | 12:04 PM
I did not adjust front
Old Mar 24, 2013 | 01:07 PM
redboost10's Avatar
Oh. I see your from France, I didn't look at the units closely, it's kgs, not lbs.
Like mentioned search the web for corner balancing and try to get the front corners as equal as possible, with you in the car and slicks.
Old Mar 24, 2013 | 01:22 PM
Yes Sorry
1065 kg or 2366lbs
Old Mar 24, 2013 | 03:27 PM
SPOOLINmatt's Avatar
Yes Sorry
1065 kg or 2366lbs
we focused on the front balance, had a 60ish variance between the rear right and rear left when done. Get ahold of lead weights to really make it perfect
Steeve_Civic
Suspension & Brakes
Apr 28, 2013 05:00 AM
portenio78
Nov 19, 2011 03:00 PM
STN_Pat
27
Sep 20, 2008 05:50 AM
ketchup
Jul 28, 2004 10:58 AM
D.CACO
52
May 8, 2004 10:46 AM
