clutch surface 2
Old May 6, 2008 | 07:08 PM
mskansan's Avatar
Default clutch surface 2
I originally posted this in tech section but no answers
I am wondering if you can freshen up the surface of a used clutch plate maybe with some sand paper or some sort of abrasive. I do know "freshening" it will take some life off the clutch. It only has a few hundred miles on it from previous car. The clutch is a Competition Clutch stage 5 with upgraded pressure plate. Any info would be appreciated
Old May 6, 2008 | 07:49 PM
Garcia-Racing's Avatar
Default Re: clutch surface 2 (mskansan)
I would say no, the surfaces have aleady been mated to each other.
Old May 6, 2008 | 08:19 PM
fast forward driver's Avatar
Default Re: clutch surface 2 (Garcia-Racing)
agreed , deal with it or replace
Old May 7, 2008 | 04:40 AM
redzcstandardhatch's Avatar
something different
Default Re: clutch surface 2 (fast forward driver)
i've taken some 220 grit sandpaper to a clutch before (for our GRM 2007$ car, and for my old daily driver).. i sanded the flywheel (orbital sander), clutch pressure plate surface, and the clutch disc (lightly)
seemed to work fine.. it probably would have been fine if i hadnt, but all three parts were used, and had never seen each other before.
budget budget budget.. good luck!
Old May 7, 2008 | 06:47 PM
mskansan's Avatar
Default Re: clutch surface 2 (redzcstandardhatch)
ok thanks for the info. If i do mess with it everything will be very lightly sanded, maybe. Keep the info coming
Old May 7, 2008 | 07:03 PM
good luck, wasnt thinking before ,,, if your doing the labor your only out what ever time it takes to swap out again if it does'nt work
Old May 9, 2008 | 03:53 AM
mskansan's Avatar
I will be doing the labor so if it f**** up i'll just buy a new clutch plate and try again
derka_si
Jun 30, 2012 08:48 PM
mskansan
May 5, 2008 06:13 AM
hondacivic_si
26
Mar 2, 2005 07:20 PM
sjteg
Jan 19, 2004 09:19 PM
2000turbosi
Nov 3, 2003 06:20 PM
