Changing Drive Axles?
Do you have to drain the tranny fliud to change change out axles. I'm just wondering, consider a break an axle at the track and I need to replace it really fast, can I do it without draining the fluid? Thanks in advance.
Depends on how the car is angled, sometimes fluid will drain out when you pull the axle out, but if you jack it up high enough on the side you're changing you'll be ok.
kpop
19
Nov 30, 2023 08:42 PM
Vagitarian
17
Aug 3, 2012 08:45 AM
civcexcoupeblack
Sep 19, 2002 04:27 AM
