CC Twin Disc help
Picked this twin up from a guy that says it has dyno time and 3 track passes on it but it looks like its had more then that on it but thats why im asking h-t cause i dont know how these things wear. Also wanted to know can i have a machine shop clean these up or should it go back to CC so i know its still balanced and good to go?? Also anyone know where i can get the tq numbers for the 6 bolts on the pp and someone use loctie on these is this somthing CC says to do? thanks
measure the discs with a micrometer. I have the specs for each disc if you need them. CC offers free inspection of their twins. That def. has more than what you said ran through it. If everything is in spec than you dont need to resurface unless it feels really un-even with your fingers. That's just how they look after a lot of cycles. **im no clutch technician**
18 ft/lbs for the 6 bolts.
Matt thanks for the info if u could give me the specs for each disc that would be great and they do fill uneven I would like to take them to my machine shop
And have them done.
And have them done.
i would reccommend sending them back to comp directly and not dealing with your local machine shop. comp usually will work with you and tell you up front whats needed
well talked with CC today about what the measurements should be new disc are .250 and mine measure .245-.246 and they would be replaced at .230 so the disc are still good for awhile the floater is should be replaced at .235 and mine was at .175 someone has turned it way down to try and fix some slipping problems or something at least i only paid 500 for it know i have to put 240 in it and ill be good to go im going to send it to them and have them put the new pp and floater in and make sure the setup height is good to go.
id do the discs also, just because theyre within the thicknes spec doesn't mean theyre gonna hold. those things are glazed over pretty good. Maybe you could send them pics that you posted and see what they recommend.
