Caster setup for z10
I have an 88 rex w/b20, I recently installed the z10 member. I can't seem to hook very well, and the car is a handful to drive. Best 60" w/22x8x13 is a 1.88, with alot of wheel spin. 215hp 146tq, 12.6 @ 111.5 spinning. What specs should it be set at for drag racing? Thanks
I would get the car on a alignment rack, the car should not be handfull, unless the caster is not even side to side. A little bit of positive caster , pre load can help, but the main thing is to make sure the caster is even side to side, and make sure your 4 wheel alignment is straight.I would also check that the upper control arm is not warn out, years ago my car got real unstable all of a sudden turn's out the upper ball joint on drivers side was shot. Make it as close to stock specs as possible. Good luck.
Jason
[Modified by littlebluecrx, 6:21 PM 2/10/2003]
Jason
