Which cams to get? JUN? CROWER? SKUNK2?
What cams and valvetrain would you guys use for your H22? This would be for an all motor drag setup. Most likely stock JDM setup, so 10.6:1 compression. Any suggestions?
does toda make toda D spec for h22?
if not jun3's, but use different valvetrain than theirs.
make sure have have an expensive header too
No...just look at the cam profiles. Toda doesn't make H motor cams and they probably never will.
Compare the JUN profiles to the Crower or Cranes...you will see that the profiles are designed more for drag then the Crowers or Cranes. Check out Skunks stuff. They are making some nice off the shelf big nasties.
Any way you go you will be able to make some pretty good power. I like the price on the Crowers. ALso...what the hell is wrong with JUN springs and retainers? Not a thing.
is rocket making h22 cams? that'll be a cheaper alternative
so u can get monster headwork.
[Modified by BoM, 11:02 PM 12/9/2002]
I got some crower stage 3`s but they are untested... we`ll see when i dyno them... nobody really knows`because not many have compared tested h series cams..we should have a tuner that does this...
I see my cams going for sale if i don`t see my target with them....
are jun cams more for top end or midrange... do they have different kinds of h22a cams from jun or only one brand....
TEGPOWER44
Jul 9, 2002 11:08 AM
