cage plates question on mounting.
Old Apr 16, 2006 | 06:44 AM
Rob!'s Avatar
Default cage plates question on mounting.
ok i have read the complete rules. somewhere i heard that no gaps can be filled using a welder.i didnt see it in the rule book though. Well where the plates need to be mounted as you know the floor is waffle shaped. Im sure that i can bend the plates in but it would take days to make them fit totally flush. so my question is can i fill the small gaps with the welder on my plates??
Old Apr 16, 2006 | 08:44 AM
stealthmode62's Avatar
Default Re: cage plates question on mounting. (Rob!)
As incorrect as people will tell you, I hit the underside of the car with a hammer in those spots to bring them up, then welded. I was really unhappy with the plates welded to the thin floor. It just didn't sit right in my head, so Tony1 suggested attaching them to the rockers and that has set my mind at ease.
If I had to do it again, I would have bolted to the floor and welded to the rockers. I don't think there is any problem (rule-wise) to doing that.
Old Apr 16, 2006 | 11:38 AM
six sigma racing's Avatar
Default Re: cage plates question on mounting. (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> As incorrect as people will tell you, I hit the underside of the car with a hammer in those spots to bring them up, then welded. I was really unhappy with the plates welded to the thin floor. It just didn't sit right in my head, so Tony1 suggested attaching them to the rockers and that has set my mind at ease.
If I had to do it again, I would have bolted to the floor and welded to the rockers. I don't think there is any problem (rule-wise) to doing that.</TD></TR></TABLE>
i know exactly what you are talking about i never weld to the floor .. its way too thin and i always attach it to the rocker sorta like this.. But as far as the floor being uneven when you go to zip the bolts in it will literally smash the waffle shaped floor and sandwich it between the plates... so you really dont have to weld...then again honda floor boards is pretty friendly..
Old Apr 16, 2006 | 03:47 PM
Rob!'s Avatar
Default Re: cage plates question on mounting. (Six Sigma Racing)
so hitting the floor board up will make it flush? i can imagine this taking a real long time.
Old Apr 16, 2006 | 06:47 PM
No, the floor is real thin. I tacked a couple edges and then took a sledge hammer and hit it from about 10 inches away at 20% throttle. It's a matter of minutes.
Old Apr 17, 2006 | 06:16 AM
Rob!'s Avatar
no ****, thanks a lot for the help.
autosport7
Welding / Fabrication
Mar 22, 2007 10:03 PM
lv6l
Oct 6, 2005 01:27 AM
danielm3
19
Oct 4, 2005 12:09 AM
georgiajdm
Honda Motorcycles
Apr 12, 2004 12:32 PM
RoAnSa
Oct 16, 2003 12:03 AM
