b20vtec vs itr
Old Apr 2, 2003 | 10:21 AM
SprayinCX's Avatar
Default b20vtec vs itr
which would you guys prefer and what is they going rate for each swap. i know the itr motor goes for around 5500.00. the reason i want to know is because i debating on which one to go with. all of my friends argu back in forth and i just wanted your input. thanks
Old Apr 2, 2003 | 10:48 AM
kill bill's Avatar
Default Re: b20vtec vs itr (SprayinCX)
id rather have an ITR...better yet a 2 liter type r. stock b20 is nothing compared to a stock itr
Old Apr 2, 2003 | 10:55 AM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: b20vtec vs itr (i need space)
a GSR with b16a head
If you're serious into building this engine you will do a port job, new valvetrain, new cams, use the GSR block and you can run some p30-PCT pistons (depending on what comp you want) Or you can get some aftermarkets with aftermarket rods. I wouldnt want to buy a ITR motor just to remove/replace everything ''type r'' except the ITR crank.... thats just me though
Old Apr 2, 2003 | 11:00 AM
LudeToAHatch's Avatar
Default Re: b20vtec vs itr (yut loc baat)
I agree... I'm not thrilled about frankenstein engines. They're more for people who can't afford to build a GSR or Type-R.
Old Apr 2, 2003 | 12:27 PM
wHOAlly's Avatar
yea, i slaughter stock itr's, cant compare em
Old Apr 2, 2003 | 01:29 PM
Brett's Avatar
Default Re: b20vtec vs itr (There is no sp00n!)
For street racing I'd rather have the torque of the b20. For track, definetly itr. Why not do b20 block w/ b16a head or b18c head? Best of both worlds.
Old Apr 2, 2003 | 04:07 PM
lazy bum shaughn's Avatar
Default Re: b20vtec vs itr (Brett)
Build yourself a nice B20/VTEC motor and you will be fast and happy.
Old Apr 2, 2003 | 08:05 PM
Default Re: b20vtec vs itr (GSRslowandswap)
ok, i think that you should run the b20vtec
itr motors are nothing....tehy are overpriced red valve cover ****
the b20 vtec is cheaper, more torque, and more hp. Same reliability.
itr motors are basically a mild built GSR.... for the price of an itr motor you could get a GSR to beat it.
anything other than a b16 and an ITR is the way to go
especially since you're going bottle
Oh man you better delete that post cause you's about to get izowned!
Man I'm not even going to start there..
A reliable B20/VTEC motor will not be cheaper than a stock R motor, and no way be as reliable(dont get me wrong, it could be reliable)
So for 4800 bucks you can get a GSR to beat a Type R motor? If you run N20 yea.
Man let the other guys handle you I'm tired lol.
Old Apr 2, 2003 | 10:52 PM
All Motor Rex's Avatar
Stock vs. Stock, ITR is way better.
What are your plans / goals for the car??
Old Apr 2, 2003 | 11:23 PM
MikeMAN's Avatar
Default Re: b20vtec vs itr (lazy bum shaughn)
gimmie the money it costs to buy a type r, and I GARUNTEE i will build a reliable b20vtec for at least 1k less
mike
Old Apr 3, 2003 | 05:26 AM
SprayinCX's Avatar
Default Re: b20vtec vs itr (All Motor Rex)
mostly a daily driver but it will have my nitrous setup on it.
Old Apr 3, 2003 | 06:44 AM
KamikazeRacinz's Avatar
ITR motor are only good if your not doing any internals..
go with a build motor, B20vtec, GSR...etc...it will be alot faster..!!
Old Apr 3, 2003 | 08:58 AM
SprayinCX's Avatar
Default Re: b20vtec vs itr (KamikazeRacinz)
i'm not looking much for building a motor. to much money for everyday driver
but looks like i'll be sticking with the itr swap.
i know tom likes the itr swap
Old Apr 3, 2003 | 09:02 AM
MikeMAN's Avatar
good luck with ur swap!!
4 lIfe!
Old Apr 3, 2003 | 11:46 AM
Good choice! A type-R engine will outperform a non-built b20/vtec in HP and reliability anyway.
Old Apr 3, 2003 | 01:56 PM
Suprdave's Avatar
Default Re: b20vtec vs itr (LudeToAHatch)
For Reliability sake, I would build a JDM ITR Bottom End...Bone Stock.
B16a Head with a fuckload of portwork...Toda Bs, and a nice SMS Header, Hondata and goto town. Basically keep stockish rev-limit and your good to go. Would have a fun-*** car.
Suprdave
Old Apr 3, 2003 | 02:34 PM
wHOAlly's Avatar
50+k mi and i walk all over itrs thank you, come again
Old Apr 3, 2003 | 02:55 PM
allm0t0rsir's Avatar
type r 2.1L block thats what i want but i would pick a typeR over a b20 anyday
Old Apr 3, 2003 | 03:04 PM
simple4012's Avatar
New User
Default Re: b20vtec vs itr (allm0t0rsir)
gsr block
rs sleeves
ls crank
Pauter rods
high cr pistons
big cams (jun3 will do, or skunk2 stage 2 is fine)
good ecu
maybe itb's......prolly not though
A GOOD header...
440 injectors
that setup right there will outperform either a b20/vtec or a type r block. Stocvk vs. stock a r motor will always win...and be way more reliable. I saw a post above that said something about the cost of a reliable motor. hows this look?
Ls block-450
ctr slugs-330
arp rods bolts and head bolts-200
BRAND NEW ITR HEAD WITH CAMS-1300
itr manifold-250
dc jdm 4-1 header-320
tranny-700
hondata-240
that setup right there will make over 200 whp for sure..........sound good to you? way cheaper too
Old Apr 4, 2003 | 11:47 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
What kind of setup? Frankly for a built B20 those numbers aren't very impressive. What times do you pull?
Any properly built setup will be reliable and with more displacement the B20 will make more power, but from what I have seen to do a proper B20 setup requires a good bit of cash.
Old Apr 4, 2003 | 01:43 PM
wHOAlly's Avatar
Default Re: b20vtec vs itr (ActiveAero)
Good choiWhat kind of setup? Frankly for a built B20 those numbers aren't very impressive. What times do you pull?
who said it was built? i quoted it saying a NON built setup wont perform....pretty nifty what 99% OEM parts will do huh?
Old Apr 4, 2003 | 06:24 PM
customx_'s Avatar
New User
yea and after hes down walking over them, i get to walk over the leftovers with my superduper slow b16!
Old Apr 4, 2003 | 10:49 PM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: b20vtec vs itr (R:L1i77)
blah, i deleted the original post,
The thread started said he wants to run NAWZZ, thats beyond me... blah....
[Modified by yut loc baat, 7:54 AM 4/5/2003]
Old Apr 5, 2003 | 08:27 AM
drvfast's Avatar
i would have to go with an itr motor. don't get me wrong the b20 vtec can be reliable if built correct and put out great numbers. the b20 vtec can not take the abuse like itr motor the b20 vtec can not handle 8200-8500 revs all the time.
Old Apr 5, 2003 | 09:02 AM
ALLMTRWHORE's Avatar
Either your joking or your a fucken moron!!!!
to the others! ok homie straight up what you going to use it for? track, drag, everyday type of driving? what?
people who get itr's want reliability ok that's cool but you'll never be fast!!! except if you build that itr!
for people who want a fass *** nutz car! will take just a block that only cost 200 bucks! and put all the nice rods, bearing and crank techniques into it! and then move on to a head! you can port it with valvetrain! get cams! and wow something that can outperforma itr head depending on who ports it!
itr motors are just nice that's it I have seen every set up imaginable and the fully built 1.8 with 210 whp will still lose due to torque!
2.0 liters are badd *** but if your going to race it get ready to pay! stick to a 1.8 if you want reliability but if you want to make 235 whp and 155 pounds of torque!!!!! build a 2.0 or up!
tell any 1.8 in the same car as a 2.0 liter 2 race and it'll be sure to back down!!! I dont care gears in both and who is driving! 2.0 for all out drag racing will win!
my 2 cents!!!!!
