b16 not starting PLEASE HELP!!!!
Old Dec 16, 2003 | 09:11 PM
RussHondaCRXVtec's Avatar
Default ******b16 not starting PLEASE HELP!!!!
my car has a b16 in it was running fine until sunday afternoon I went out to start it and it idled fine for about 20-30 sec then completely shut down. It will turn over fine just won't start. so I went in this oder of what I replaced Cap, Rotor, spark plugs, igniter, wires, coil, and it still won't start cause i'm not getting spark.
tell me what it could be I'm thinking my ecu.
how do I read trouble codes???
could the Ecu be telling the motor not to start because something else is wrong??
please help I've wasted like 200 bucks and i'm sick of riding the bus. thanx
Old Dec 17, 2003 | 06:02 AM
b19coupe's Avatar
Default Re: ******b16 not starting PLEASE HELP!!!! (RussHondaCRXVtec)
This is not the forum to ask that question-try tech. You will get more responses-lots of them wrong
Start with basics-verify that the timing belt is o.k.-the cam timing is correct, and that the cams turn when you crank the motor. Make sure that the ignition rotor is turning when you crank the motor. Check compression. Make sure that G101 is properly connected-that's the ground by the thermostat housing. Check all of your fuses. These kinds of problems often turn out to be something really simple. Best of luck.
Old Dec 17, 2003 | 04:13 PM
toyotaturbo's Avatar
check the timing belt, distributor, ignition coil and the igniter.
shawn_090
Jun 24, 2008 01:03 PM
.doeboyfresh.
Mar 24, 2008 06:27 AM
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
