ATI Dampner question Bseries
Hey guys...starting putting my motor back 2gether and I had ordered a ATI dampner for it. Well the stock crank pulley goes on/off fairly easy. When I went to put the ATI on it got tight on the crank shaft really fast. So pulled it back out. Started reading and people have said that u got to mic the crank and machine the dampner to slide on....does this sound correct to u guys? Anybody running these dampners and how smooth did ur install go? Thanks guys. Any help is much appreciated.
I have a street version and it is the same. I have not tried to force it on yet since I have lots of other things to do. I would hate to have to machine it right. That would through of the balance and everything.
They are a press fit, it is absolutely necessary to be pressed on in order to function correctly if they are not tight they won't do their job. To the people that machined them....lol might as well be running one of those chinese blue ebay pulleys.
Here are a couple of good reads...
http://www.atiracing.com/products/dampers/101/index.htm
http://www.atiracing.com/products/da...mper_dinan.htm
And you will need this type of installer/remover for easy on/off.
Warm the hub then it should go on a little easier, I used the oven in the house warmed it to 90 degrees started to slide on then finished the rest with a long bolt and some big washers.
They are supposed to be tight to work properly as previously stated. Use anti-seize on the June and crankshaft block of wood and a BFH if you don't have access to a pulley installer. Don't have at it like an animal either. Pulley puller works wonders for removal. If using the block
And hammer method remove the outter inertia ring and only put it on by the hub. Bolt on the ring later
I just put the hub on and ran the crank pulley bolt down with an impact... That pulled the hub down tight. Nothing fancy it's just a tight fit. I haven't had any problems doing it that way.
I have always done it this way with zero install problems, but i back off the bolt and then use a torque wrench for the final 140# torque amount.
I started to do it that way but it got tight fairly soon...and I didn't wanna mess it up so I quit and backed it back out. Was afraid of stripping the crank. Might try the heating method 2marrow, maybe even set the block by the ac vents in the house to get the crank shaft cold..... If not it will go to the machine shop mon...thanks guys
My fluidampr was the same, I used a thin layer of antisieze to avoid galling and the crank bolt to drive it on with an impact gun. Just gotta be easy with the gun. And to remove the kit shown above works wonders
The pulley is intended to be an interference fit per the instructions. You need to get hold of a harmonic balance remover tool to get them off or other creative means.
Like others, I just tightened it on with the crank pulley bolt, slowly with a wrench to make sure it was going on ok. Final step to torque bolt.
Too much thinking here lol!
I just put anti-seize on mine and push it on as far as it'll go and use the crank bolt to press it on and be done! No probs here!
tap it on with a rubber mallet until you are sure its going on strait, then use the bolt to pull it in... I use a gear puller to get it off though.. its a bitch.
Get a brake cylinder hone from any auto parts store, and a drill. Use some oil with the hone. You don't need to go crazy. Just hone it for a few minutes. Also any lube on the crank and hub will work. Don't use too much as you don't want it all over the T-belt. Don't forgat lube on your crank bolt, and torque to spec.
