ARP head studs torque specs
Official Instructions from ARP:
install studs with double nut
make snug then quarter turn
Install at 70lbs
Heat cycle 10times (heat then cool for 30 min)
loosen each stud then retorque to 75lbs
installation without ARP moly is not recommended
Install at 70lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 »</TD></TR><TR><TD CLASS="quote">Official Instructions from ARP:
Install at 70lbs
wow i thought it was hand tight?
Install at 70lbs
yes, i know but we have done much testing and have not had good results with hand tightening. when asking arp about the problem they gave me the instructions i posted.
Hand Tightening Sucks...I always double nut that **** with Moly Lube.
I'm really **** about making sure all the studs are perfectly even...anyone else?
Suprdave
Suprdave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Hand Tightening Sucks...I always double nut that **** with Moly Lube.
Suprdave</TD></TR></TABLE>
same here
same here
I double nutted the studs to 20 ft/lbs, then did a three step tightening on the nuts... something like 25, 55, then 72. I clened the stud holes (in the block) with air to make sure they were clean, then used assembly lubs on the studs, and on the nuts.
Im replacing my oil pump this week and I will see if they are at the same levels.
I didn't have much luck trying to just hand tighten the studs into the block. After I got done, each stud was at a slightly different height. I torqued them down to 10 ft-lbs (double-nut) and that put each stud at exactly the same height.
Sonny
Please don't take offense to this personally but that is a ridiculous thing to do and makes no sense at all. If someone at ARP told you to do that, I would love to have their name.
Re-torquing head studs has to do with the type of head gasket you use and not the stud. No Honda head gaskets available today require this. Why would you take a perfectly sealing head gasket and loosen all the nuts, break the seal and then chance warping the head by re-torquing each bolt to a higher number. Whoever put this advice out should be fired and I would love to tell him that to his/her face.
Having said this, if you want, you can go in after one recycle and RE TORQUE the nuts to the exact same pounds as before just to see if all is ok. Never loosen or torque to a higher poundage.
As far as installing the studs, you can put them in hand tight if you run a tap down the threads in the block first and clean them perfectly. However most people don't have the ability or the tools to do this so it is ok to torque the studs down to 5 lbs or so in order for them to be at an equal height in the block. Any more than 5lbs actually negates the clamping values of the studs.
If you do retorque and you find one very loose, something else is failing (probably the threads in the block). Anymore than 75lbs of torque on a Honda head puts you in danger of warping the head.
i had a problem yesterday with my head studs....i put them in hand tight then did double nut quarter turn like arp said to do...so first i torqued them at 32lbs then i torqued them at 52lbs..then for the final step i went to torque them at 76lbs...but when i went to 76 i think the bolt was turning in the block further cuz it never torqued at 76 it just got tighter and i know i was over torqing it..so i stopped and now im stuck...and i dont know what to do...i broke em all lose again so i can start over but i wanted input on what to do.....has anyone had this problem b4?......hoping u guys can help me out....thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">
If you do retorque and you find one very loose, something else is failing (probably the threads in the block). Anymore than 75lbs of torque on a Honda head puts you in danger of warping the head.</TD></TR></TABLE>
As I mentioned nefore we were told the same thing twice when we called ARP. We were weary on actually loosening and retorquing however so we just pulled the cams and retorqued or checked the torque only without loosening since it would break the seal n the headgasket. Our thoughts exactly Earl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny »</TD></TR><TR><TD CLASS="quote">
When is the eyeball gonna move, earl?
Sonny
Yeah it's kinda scary him watching us all the time , huh Sonny? SPOOKY!
Sonny
