ARC 8000 Switch Panel
Old Jan 16, 2015 | 10:08 PM
acrocat's Avatar
Default ARC 8000 Switch Panel
I am looking at buying the ARC 8000 switch setup. Was wondering if anyone had any feedback about it and where the best/cheapest place to buy one is.
Old Jan 17, 2015 | 12:40 AM
93ericSi's Avatar
Default Re: ARC 8000 Switch Panel
They are about $30 cheaper on jegs than summit. Don't know if someone has found cheaper. But Google shopping will be your best friend in finding it for good prices.
Old Jan 17, 2015 | 05:40 AM
SPOOLINmatt's Avatar
Jegs is the least expensive. Someone might crawl out of a hole and offer otherwise though haha.
Just got mine from Jegs.
Old Jan 18, 2015 | 09:38 AM
imptricer's Avatar
jegs...i love my arc panel wouldnt have anything else now
Old Jan 18, 2015 | 11:36 AM
NWDyno's Avatar
Hard to beat jegs these days with their free shipping and discount. 8 switch arc panel for 260 shipped is a great deal.
Old Jan 18, 2015 | 04:45 PM
is everyone running their fuel pump directly off the ARC itself? or is anyone using the ARC output to engage another relay with fuel pump on that one?
Old Jan 18, 2015 | 05:34 PM
itspools's Avatar
My ARC runs my Magnafuel Pro Tuner 750. No issues.
With that said, love my ARC switch panel.
Old Jan 18, 2015 | 06:18 PM
CO_RaceFab's Avatar
weldon 2345 straight off the board... super nice product imo so simple and extremely versatile.
Old Jan 20, 2015 | 09:28 AM
10sec4door's Avatar
Best money I ever spent on my car. wired her up with no issues.
Old Jan 20, 2015 | 07:24 PM
There we go!
Ive been running an aeromotive Pro and they are pretty hungry, not as much as the 2345 however.
Old Jan 21, 2015 | 03:17 PM
95dxsir2's Avatar
So you guys are running the fuel pump with no relay and using the ARC switch on the power side with no failures?
Old Jan 21, 2015 | 09:27 PM
93ericSi's Avatar
The ARC comes with a panel that has relay for each switch.
Old Jan 27, 2015 | 06:34 PM
CO_RaceFab's Avatar
it has its own relay board its seriously idiot proof .... matt im also on 16v system if that says anything about the quality of auto rod control products
Old Jan 28, 2015 | 09:09 AM
locash's Avatar
ARC 8000 here too, works great, but I am thinking about switching to a Motec PDM to clean things up a bit. Never an issue with the ARC unit, I'd recommend it..
Old Jan 28, 2015 | 06:06 PM
Twenty47's Avatar
Use the 8000 in my 16v all motor car. Love it. Wired the whole car from it and was a breeze. No oem wiring left in the car.
Old Jan 29, 2015 | 12:45 PM
Andrew1706's Avatar
I got the 4000 and now I regret it, not enough buttons!
Old Feb 2, 2015 | 05:48 PM
a1320addict's Avatar
It's a decent kit for the money, and is simple enough for anyone to install (even those without any wiring experience) - but it has a few downfalls:
-Open PCB, should be put into an enclosure. Anything conductive dropping onto the board when the car is on and that's it.
-Ribbon cable from switch to board is not the most rugged, connections for both are LIF unsealed - similar to those you'd find in a desktop computer
-No option to trigger relays from anything other than the switch - without heavily modifying the board. Think: car crashes, you're knocked out, but your fuel pumps are still running.
Old Feb 3, 2015 | 03:02 AM
That's what your kill switches are for, and I have two of them
Old Feb 5, 2015 | 08:42 PM
I don't agree. When an ECU is capable of controlling a relay if there's sync - then you're best off using it for your fuel pump(s). A kill switch is not a replacement for this.
Old Feb 6, 2015 | 03:33 AM
You're talking about in the instance of a crash correct? I have to kill switches connected to the same main power breaker that feeds the whole car including the relay board. I think that's about the only way to accomplish this lol
Old Feb 8, 2015 | 06:55 PM
The only way a kill switch will help you in turning off a fuel pump that is wired to a switch only trigger like your saying is:
A) you have a push/pull style switch that is mounted in the area the car hits - and the wall actually pushes the switch off
B) you hit in a way that your BAT + shorts to NEG - and your breaker trips - removing the power input to the ARC and in turn any relay with it's switch 'on'.
This is all worst case scenario and assuming the driver is unconscious and can't turn the cabin mounted kill switch or fuel pump switch (in this example) off. It's safety...cheap and easy shouldn't be a part of it getting done.
integra_101
Jul 29, 2014 07:25 AM
David12
Nov 16, 2009 04:45 PM
jdmyelloweg
Mar 30, 2009 02:53 PM
alacard
Audio / Security / Video
11
Jan 12, 2007 07:27 PM
EKB18BPR3
51
Jan 18, 2003 12:55 AM
