Anyone try raxles?
Old Jan 10, 2010 | 06:17 AM
92redhatch's Avatar
Default Anyone try raxles?
Right now I can't afford DSS axles and I keep breaking my autozone lifetime warranty axles. A friend of mine told me raxles hold a decent amount of power and they're not that expensive. Does anyone have expierience with them?
Thanks
mike
Old Jan 10, 2010 | 06:43 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Anyone try raxles?
hrmmmm that name rings a bell, and for some reason it doesn't seem like there were many people with good things to say about them. Try searching the archives back about 4-5 yrs ago
Old Jan 10, 2010 | 07:17 AM
TDautowerkes's Avatar
contact glenn @ gator axles if you are on a budget... DSS is still full of WIN!
Old Jan 10, 2010 | 07:41 AM
92redhatch's Avatar
Gator axles? Reliable?
Old Jan 10, 2010 | 07:47 AM
portenio78's Avatar
I have had my raxles for about 3 years now and no complaints. Great customer service as well.
Old Jan 10, 2010 | 07:55 AM
92redhatch's Avatar
Have you tried them out on the drag strip with slicks?
Old Jan 10, 2010 | 12:37 PM
TurboManny's Avatar
whatever you choose to do make sure you go with big outer hub if you choose to go with the factory hubs you will most deff. going to have problems.
Old Jan 10, 2010 | 12:54 PM
boostedcivicsir's Avatar
Mr. Badwrench
tried raxles once. the guy told me i was an idiot on the phone when i told him his axles were causing a vibration, and my dss's in the same car werent. so ill never deal with them again.
had the "green ones" c/s was ok, but was expected to pay for an axle that broke again when the wrong inner was installed. sold them with the 5 lug, went dss 5.9 best move i made.
Old Jan 10, 2010 | 01:25 PM
92redhatch's Avatar
Do raxles come with the hub?
Old Jan 10, 2010 | 02:08 PM
Mr. Badwrench
the ones i used were stock replacements, i dont know if they use a larger hub like dss.
Old Jan 10, 2010 | 03:01 PM
92redhatch's Avatar
What company sells the larger hub by itself?
Old Jan 10, 2010 | 04:32 PM
portenio78's Avatar
Yes numerous passes with them at the strip. I like how they are balanced with the factroy style rubber ring on the axle.
Old Jan 10, 2010 | 05:44 PM
REEMB18C1's Avatar
id rather try the obx knock off axles over gator!!! but dss is where its at
Old Jan 11, 2010 | 10:39 AM
92redhatch's Avatar
Do they come with the bigger hub?
Old Jan 11, 2010 | 10:47 AM
92redhatch's Avatar
I talked to Marty from raxles and he said he doesn't sell performance axles only oem replacements. He said they are stronger then the autozone Chinese ones but not strong enough for what I need. And he doesn't sell them with a bigger hub.
Old Jan 11, 2010 | 01:18 PM
Mr. Badwrench
i have a question when it comes to the autozone chineese ones, does raxles have a lifetime warranty? hahaa. i know guys that will buy 50 sets of zone axles before they throw down on expensive axles.
personally i would go with the zone before raxles strictly on the way i was treated when i called them.
Old Jan 11, 2010 | 02:21 PM
nonvtecallmotor's Avatar
I'd rock the stock ones before I bought something other then a DSS.
I bought my DSS (stage 5's now 3.9's) used a few years ago and they are still holding up great.
Old Jan 11, 2010 | 05:49 PM
92redhatch's Avatar
Zone have lifetime warranty. I'm on my 3rd drivers side axle
Old Jan 11, 2010 | 06:23 PM
I.C.C.'s Avatar
I currently run stock axles for the simple fact that I would rather break an axle, then break something else in the transmission... I figure if the car hooks really hard, or gets any type of wheel hop, or anything else that would cause something to break, I would rather it be a $50 part than a $500+ part, not to mention the down time... I can bring spare axles to the track to drive the car home, but I don't carry spare transmissions...
Old Jan 11, 2010 | 06:49 PM
xsi-t's Avatar
buy some real axles and build a real trans. when u step up and make big boy numbers you need matching parts.
Old Jan 11, 2010 | 07:06 PM
Really? A True Street CRX that I tune runs 9.6 @ 153 with a stock trans and stock axles. Over 100 passes on them both....
Old Jan 11, 2010 | 07:14 PM
rota92
Guest
Posts: n/a
You and I both know that's a tough combination to come by, good enough OEM parts, proper setup and a proper driver.
Most guys who break stock ones will still break aftermarket stuff in due time, it will just take longer lol
But I do agree, before buying anything BUT DSS keep rocking the stockies
Old Jan 11, 2010 | 07:22 PM
xsi-t's Avatar
Not everyone can pull that off. some people cant drive correctly or take shortcuts. If you have made it on stock axles more power to you but i was commenting on icc post
Old Jan 11, 2010 | 09:23 PM
devsol's Avatar
dss axles ftw. but i have also used insane shafts axles. on my street track car and they held up make 600whp on a 24x9 slick and 25x8 slick without a problem and if u on a budget. i like them but none the less dss ftw. if u trying to make big power and run with the big boys.
Old Jan 12, 2010 | 02:52 AM
92redhatch's Avatar
I have no wheel hop and I'm preloading. Maybe I'm launching with the antilag building too much boost or too high of an rpm.
