2000 civic engine questions
Old Sep 5, 2018 | 12:45 PM
RACER69MAN's Avatar
Default 2000 civic engine questions
my daughter has a 2000 civic dirt track car. the class she is running the cars are supposed to remain stock. trying to figure out things i can do to help with performance:
1) need to have more throttle on take off.
2) what do i need to be running timing on?
3) when car gets hot, it idles too low(500 rpm or lower) and wants to die.
she is running the car in 2nd gear all the time.
thanks in advance for any help you can give me with this.
Old Sep 5, 2018 | 08:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2000 civic engine questions
The cars are "supposed" to be stock... this is code for "the front runners are cheating and haven't gotten caught yet". The low idle is likely an IACV problem. If the car is lightened up and the accessories have been removed... and you are running premium unleaded fuel... you can increase the ignition distributor timing 3 or 4 degrees. I am not sure what you mean when you say "need to have more throttle on take off" since you are not drag racing... so maybe you can clarify that and then I can offer a suggestion.
Since your daughter has a 2000 Civic, I suggest you drop in a DOHC "B" series engine swap (I am assuming the car has a manual transmission here) and stick a couple "Si" badges on the front and rear. The race tech will likely not be savvy enough to be able to prove that a DOHC engine is "illegal", even if you use a 1.8L GSR engine.
Old Sep 6, 2018 | 04:34 AM
RACER69MAN's Avatar
WHAT I MEAN BY MORE THROTTLE ON TAKE OFF, THE CAR NEEDS A LITTLE BIT MORE POWER WHEN THEY START THE RACE AND ON RESTARTS. THE STARTS AND RESTARTS ARE A ROLLING START(ABOUT A 1000-1200 RPM). THIS CAR IS AN AUTOMATIC.
Old Sep 7, 2018 | 07:04 PM
hybridnorth's Avatar
Automatic is your problem, nothing you can do about that. No such thing as a shift kit for a d-series Honda transmission.
Old Sep 8, 2018 | 11:38 AM
rudebwoy's Avatar
I would go with an older chassis 92-95 si SOHC Vtec, manual transmission, maintained, remove unnecessary accessories, upgrade or renew suspension bushings.
Old Sep 8, 2018 | 06:53 PM
sneakysneaky's Avatar
Send the cam to JG for a regrind. You will need to find a tune for an automatic and that will be the hard part. Most people end up using a vafc or similar patch work tune. You can do some minor head work or a zc swap but casting numbers are not your friend if the motor is supposed to be stock.
Minor tricks to pick up 10-15 hp can be pretty rewarding, but you have to go through some pretty amazing lengths to do more. I’ve seen people go through the trouble of cutting out casting numbers from broken heads and welding them into good heads.
Boring out intake manifolds then using wax or epoxy to fill then machining back to stock. The casting flash can be imitated with sand before painting. But when someone measures the ports expect to be banned from that sanctioning body, not worth it in my humble opinion.
Dgwelch
Nov 28, 2017 06:17 AM
SIBlue00
Jun 11, 2009 02:38 PM
freddysEF
Jun 27, 2007 06:54 AM
