b16a cable transmissions
Old Jan 12, 2004 | 07:25 PM
ninesecrx's Avatar
Default b16a cable transmissions
I have 2 b16a cable transmissions. Both have the 4.40 final drives....
one is in perfect condition-$500
one might have some syncro problems but does into gear $250
Im located in southern California so pickups only, no shipping.
Old Jan 16, 2004 | 12:17 AM
ninesecrx's Avatar
Default Re: b16a cable transmissions (ninesecrx)
up...
Old Jan 16, 2004 | 09:06 AM
turbochic's Avatar
bump for trannies......
ppl purchase these thangs...
Old Jan 18, 2004 | 05:15 PM
turbochic's Avatar
bump
Old Jan 19, 2004 | 05:37 AM
1's Avatar
Default Re: b16a cable transmissions (turbochic)
Mike, which tranny is the bad one?
Old Jan 19, 2004 | 06:39 PM
ninesecrx's Avatar
Default Re: b16a cable transmissions (1)
The one that says bad on it
Old Jan 19, 2004 | 06:47 PM
1's Avatar
No, what code is it?
Old Jan 19, 2004 | 06:50 PM
ninesecrx's Avatar
Im not good with chassis codes, so heres the gear ratios of both trans.
1- 3.230
2- 2.105
3- 1.458
4- 1.107
5- .848
with a 4.40 final drive
Old Jan 19, 2004 | 06:52 PM
1's Avatar
Is there no code sticker on it?
Old Jan 19, 2004 | 06:58 PM
ninesecrx's Avatar
nope...but they have both been open and I counted teeth so I know what they are...thats even better then a gold sticker that says a code.
Old Jan 19, 2004 | 07:38 PM
1's Avatar
Mike, is it 89-90 or 90-91?
Old Jan 19, 2004 | 07:52 PM
ninesecrx's Avatar
I dont know...
Old Jan 20, 2004 | 04:23 AM
1's Avatar
So, are you saying you have never used them yourself? Try sticking a 92+ clutch disc on it and see if it fits.
Thanks,
john
Old Jan 20, 2004 | 07:25 AM
earl's Avatar
They are small shaft trannys
Old Jan 20, 2004 | 08:47 AM
tz-devil77's Avatar
Default Re: b16a cable transmissions (earl)
sorry to jack the tread but i only have one ?
What is the dif, earl jsut said small shaft transmission!
Old Jan 20, 2004 | 11:04 AM
ninesecrx's Avatar
They are small shaft b16 cable tranys...88-91 jdm all came small shaft. 92-93 american ls and gsr came big shaft.
These are 88-91 JDM (non-lsd diff.) trans. with a small shaft.
Old Jan 20, 2004 | 11:05 AM
ninesecrx's Avatar
I have used the beat up one, but not the other. I have opened up both for inspecion and to count teeth...thats why I know what the gear ratios are...
Old Jan 20, 2004 | 11:07 AM
tz-devil77's Avatar
i have a cable lsd trans from japan on my del sol. ya now it has a prob.
So if i replace wiht one of these what is the clutch i need, is that the shaft your talking bout or is it a internal one
Old Jan 20, 2004 | 11:13 AM
ninesecrx's Avatar
Default Re: b16a cable transmissions (tz-devil77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tz-devil77 &raquo;</TD></TR><TR><TD CLASS="quote">i have a cable lsd trans from japan on my del sol. ya now it has a prob.
So if i replace wiht one of these what is the clutch i need, is that the shaft your talking bout or is it a internal one</TD></TR></TABLE>
You would not want one of these transmissions because they are cable style where as you have and need a hydrolic trans...
Old Jan 20, 2004 | 11:18 AM
tz-devil77's Avatar
i am trying ti find out the difference in the small shaft deals and everything. Cause i will need to be looking for one to rebiuld so these would be a good candidate!
Old Jan 20, 2004 | 11:48 AM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tz-devil77 &raquo;</TD></TR><TR><TD CLASS="quote">i am trying ti find out the difference in the small shaft deals and everything. Cause i will need to be looking for one to rebiuld so these would be a good candidate!</TD></TR></TABLE>
Parts from the big shaft and small shaft are not interchangable...
Old Jan 20, 2004 | 12:25 PM
tz-devil77's Avatar
so will the clutch you have for sale work on these transmissions?
Old Jan 20, 2004 | 01:20 PM
ninesecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tz-devil77 &raquo;</TD></TR><TR><TD CLASS="quote">so will the clutch you have for sale work on these transmissions?</TD></TR></TABLE>
Yes, it will...
Old Jan 22, 2004 | 08:01 PM
ninesecrx's Avatar
7up
Old Jan 23, 2004 | 04:41 PM
ninesecrx's Avatar
