Classic Hondas All Pre-1988 Hondas.
87 crx starting problem
Old Feb 19, 2009 | 12:30 PM
veritasaequatis's Avatar
Default 87 crx starting problem
having a hard time keeping her running. the fuel pump will cut on and at the end of the cycle it will start, all good. i get back turn the car off wait about 15 minutes go out agian to start it and it doesnt start, no fuel pump noise, nothing at all. im thinking alternator or a loose ground wire somewhere possibility a battery anyone else have any insight?
Old Feb 19, 2009 | 12:46 PM
1grex's Avatar
Default Re: 87 crx starting problem
Originally Posted by veritasaequatis
nothing at all.
nobody wants to believe this or check this out b/c it sounds too simple, but its probably a battery connection. tap/check battery post to terminal connections, & terminal to cable connections.
Old Feb 19, 2009 | 02:40 PM
tried that i get lights lights and instrument panel but no fuel pump and wont start
Old Feb 19, 2009 | 07:42 PM
bump
Old Feb 20, 2009 | 02:59 PM
1grex's Avatar
Check the fuel pump fuse & if there is power there. Sometimes low resistance (bad) pumps will blow the fuse.. Next step jump 12 volts to the fuel pump. If pump does not run replace pump. If pump runs, suspect main relay or wiring between main relay & pump in that order.
Old Feb 20, 2009 | 05:32 PM
78CITYTURBO's Avatar
Maybe main relay, fuel pump or clogged fuel filter or bad ecu.....
boost16awd
10
May 19, 2017 10:21 AM
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
lakahang
Aug 11, 2011 07:37 PM
rx_86
Apr 1, 2010 04:49 PM
progressivedrunk
Oct 19, 2003 05:45 PM
