Classic Hondas All Pre-1988 Hondas.
1980 Accord Engine damage
Old Jun 4, 2020 | 10:15 PM
MosheUtiw's Avatar
Default 1980 Accord Engine damage
I cant find where to post about an antique Accord, so ill post here. I changed my timing belt and was a couple teeth off. Car ran but started to overheat.
compression had been from #1 to #4 105 120 120 120
Redid belt to what looked correct now that i know to check TDC on flywheel many times and line up with cam many times and now i find compression is 60 90 90 90...did i bend valves? Blow gasket when it heated up? What would cause such an even drop in compression? Car does not run now
Old Jun 4, 2020 | 10:33 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1980 Accord Engine damage
If your timing belt was off enough you may have caused the pistons and valves to make contact.
Scroll down further there is the Classic Hondas forum lower down.
Old Jun 5, 2020 | 09:46 AM
99stockcivic's Avatar
Wow, that's the last of the CVCC type engines, and still carbs too. But no CAT .
I agree, I believe that is an interference engine. Family had a 1979 Civic, I think similar engine.
It does sound like you bent all the valves.
Old Jun 14, 2020 | 12:07 AM
MosheUtiw's Avatar
When i turn the engine by hand with spark plugs out, oil is squirting out of the number 2 cylinder. Is that a hole in the piston?
Old Jul 13, 2020 | 12:43 PM
SiR_H's Avatar
I second 99stockcivic's analysis, sound like bent valves to me as well... Getting the timing perfectly is crucial after changing the belt. I wish Honda would mark the timing on the teeth like Mercedes does (or used to do) however.
C. Amick
Apr 4, 2016 05:35 PM
mothornton
Dec 29, 2011 06:57 PM
neonphire8604
Dec 31, 2009 01:19 PM
Dave_Darling
12
Jul 12, 2007 08:40 PM
jb734
Jul 1, 2003 08:09 PM
