AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
ED Civic AWD conversion?
Old Dec 18, 2020 | 05:57 AM
Flip Acre's Avatar
From: Cheney. A little town outside Spokane Washington.
Default ED Civic AWD conversion?
Can you do the EF AWD Swap on an ED Civic of the same year so long as you also swap the tranny, knuckles/spindle and axles? The only difference I know of is that one is JDM and the other is Canadian.
I want to know because I have an ED Civic that I'm swapping in EF axles, transmission, knuckles, half-shaft, and a D16Y5 that I'm putting a built Y8 head on with a tuned P28 ECU. I hope to turbo it by putting in a spacer and increasing the combustion chamber through machining. That or do a vitara build which is simpler, and after I'm done driving it into the ground I want to know if I can convert it to AWD and run big power or not. Like a B or K swapped EF Civic can on the street.
