AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
Awd swap handbrake disconnect
Old Dec 15, 2023 | 04:50 PM
Philopoto's Avatar
Default Awd swap handbrake disconnect
Hi, I've been looking around online for a while. I'm building a CRX rally car fwd but I am curious if I did an awd crv swap if there is a way to disconnect the rear wheels when pulling the handbrake? I was thinking I would do the clutch pack and quick spool center diff options, and don't want to wreck them using the handbrake.
thanks
Old Dec 15, 2023 | 05:20 PM
Ryanthegreat1's Avatar
Default Re: Awd swap handbrake disconnect
The dual pump rear ends do have a thermal bypass.... Maybe rig something in place of the thermal valve.
Pulling the handbrake opens the valve and dumps the hydraulic pressure that clamps the clutch packs.
Old Dec 15, 2023 | 05:41 PM
Philopoto's Avatar
ok that's the type of idea I'm looking for. Thanks.
If anyone has done that it'd be awesome to hear about it
Old Dec 18, 2023 | 02:58 AM
DaX's Avatar
DaX
Loved
Community Favorite
There is a post on here somewhere about a person that build a car with a CRV rear end and modified it to use an air locker system. Maybe you could make a switch that is activated when you pull the handbrake to dump the air and unlock the rear.
Old Dec 20, 2023 | 08:33 AM
Philopoto's Avatar
interesting thank you
God Eater
17
Nov 23, 2012 07:08 PM
dopeciv608
Apr 2, 2010 04:32 AM
GRANDE7652
Jul 31, 2006 01:55 PM
civicmark
Aug 14, 2002 10:34 AM
