wiring diagram?
12volts white + brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Second Starter none
Ignition black/yellow + brn conn abv fusebox
Second Ignition none
Third Ignition none
Accessory yellow + brn conn abv fusebox
Second Accessory none
Keysense
Power Lock green/white - in drivers door
Power Unlock green/red - in drivers door
Lock Motor none non none
Unlock Motor none non none
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt green/red - driver kick panel
Dome Supervision none non none
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin none
Trunk/Hatch Release none
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock none non none
Tachometer blue AC 2-pin plug near distr.
Wait to start
Brake Wire green/white + brake pedal switch
Parking Brake
Horn Trigger blue/green - steering column
Second Starter none
Third Ignition none
Keysense
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Hood Pin none
Power Sliding Door
Wait to start
Parking Brake
mattssi
Audio / Security / Video
11
Sep 29, 2005 12:07 PM
