wiring an amplifier... some help.
Old Jun 1, 2005 | 07:36 PM
idriveadelsol7's Avatar
Default wiring an amplifier... some help.
i have a precision power dcx 1000.1 amplifier. it's a monoblock by the way... can that amplifier be bridged? it's currently set up like this:
(-)(+)(+)(-) <- those are the speaker terminals.
Old Jun 1, 2005 | 07:52 PM
fcm's Avatar
fcm
Old Fart
Default Re: wiring an amplifier... some help. (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i have a precision power dcx 1000.1 amplifier. it's a monoblock by the way... can that amplifier be bridged? it's currently set up like this:
(-)(+)(+)(-) &lt;- those are the speaker terminals.</TD></TR></TABLE> NO Its a monoblock, it is only one channel they just give you 2 neg. and pos. speaker term. to make it easier to wire two subs up, if there are 2 speaker term. on the sub box. 94
Old Jun 2, 2005 | 06:22 AM
strictlyimport's Avatar
fcm is exactly right. you can't bridge an amp that has only one channel. the point of being a mono amp is so you can put all the power to the sub(s).
Old Jun 2, 2005 | 07:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: wiring an amplifier... some help. (strictlyimport)
Thanks for the conformation, but the point of a mono block amp is that it is only one channel, and even though they are marketed as sub amps, and some can only be used as lowpass amps, you only need mono for sub bass, there is little or no left right separation at sub bass frequencies, that does not mean you can't use mono block amps on highpass, one for the right channel and one for the left channel, I have done that lots of times, even 5 mono blocks one each for left and right front and one each for left and right rear, and one for the sub/subs, but then you can also use a 2ch amp on one side, [bi amping] one channel to the mid. and the other to the tweeter, [works best with 2ch amps that have both "left and right" gain controls. 94
NuRon
Audio / Security / Video
Jul 1, 2008 07:01 AM
TheTealHatch
Aug 22, 2006 12:53 PM
MilanoCivic97
18
Mar 23, 2006 07:02 PM
sykotic
Aug 27, 2004 06:49 PM
jv144
Jun 1, 2004 06:57 PM
