Wire question, there are arrows on the wire.
Old Oct 16, 2003 | 03:43 PM
Torridcivic's Avatar
Default Wire question, there are arrows on the wire.
I just bought 100ft of RCA wireing there are arrows on either side of the writing where it says "HIgh resolution audio interconnect cable - OFHC Double sheilded" the arrows both point the same direction on the wire. I am guessing that this means that the current should flow in this direction.
What would cause this? WHy would there be a difference?
Old Oct 16, 2003 | 04:31 PM
1BlackHatch's Avatar
Default Re: Wire question, there are arrows on the wire. (Torridcivic)
Dude you better delete this post quick.
Old Oct 16, 2003 | 06:05 PM
vteg's Avatar
New User
Default Re: Wire question, there are arrows on the wire. (1BlackHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">Dude you better delete this post quick.</TD></TR></TABLE>
Haha
Analog sound signals are ac. So the current goes both ways, so there is no correct direction. Unless there is some mystic voodoo I am missing.
Old Oct 16, 2003 | 06:17 PM
Xazzu's Avatar
only direction I've seen on anything speaker related was when I had some resistors. ??
Old Oct 16, 2003 | 08:31 PM
rjr162's Avatar
Default Re: Wire question, there are arrows on the wire. (Xazzu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xazzu &raquo;</TD></TR><TR><TD CLASS="quote">only direction I've seen on anything speaker related was when I had some resistors. ??</TD></TR></TABLE>
No, the Monster Cable I201XLN's have the arrow also. it's because they had a grounding connection on one end of the RCA lines that you were suppose to connect to the signal sending unit (Head unit). The arrows were suppose to show which way the audio path would follow. It was suppose to help with noise reduction and blah blah, but I never sold them anyhow. Always sold the Micro's since they were much nicer to hide
Old Oct 17, 2003 | 07:56 AM
Default Re: Wire question, there are arrows on the wire. (rjr162)
Thanks guys, AC? I thought that RCA cable just sent electrical pulses in the form of Binary code that the amp picks up and amplifies. I put all the wires in with correct facing arrows, I don't know if it will help but hey I might as well try to do it right.
Old Oct 17, 2003 | 08:31 AM
Alternating Current. Sine wave. Not binary at all. Analogue at it's finest.
rsdriver17
Mar 10, 2007 09:59 PM
DC2 Mang
May 19, 2006 06:42 PM
JDM_Frijoles
May 18, 2006 10:17 PM
JDM_Frijoles
May 18, 2006 09:37 PM
Dunc
Mar 20, 2005 12:26 PM
