Will this setup work out nice in my Jeep?
Old Jun 12, 2004 | 09:03 AM
slvrcivic97's Avatar
Default Will this setup work out nice in my Jeep?
I used to own a 97 civic and never got around to getting my system set up because I sold it. I now own a 96 Jeep grand cherokee limited and know that it's going to take alot more juice to make my system louder than the civic.
I don't want to listen to Death defying loud pounding in my car, but would like the peice of mind knowing that if I ever want to crank the loudness up, that it will be there. For everyday use though, I just want some louder base. My main concern is if you think my future setup below will be "enough" to make my jeep sound good.
I already have an infiniti sound system in the car so do you think I should still upgrade the speakers?
Alpine CDA-9833 Headunit
SPR136A 5-1/4" Type-R Component 2-way FRONT speakers
SPR694A 6x9 Type-R Coazial 2-way REAR speakers
SWR-1241D (2) 12" Type-R Subwoofers (4ohm + 4ohm)
or do you think 1 is enough?
I have no idea what kind of amp I should be looking at.
If you guys think I only need 1 12" type R to bump my jeep, then what amp would you reccomend?
What Kind of amp should I be looking at?Mono Amp, 2-Channel Amp, or Mulit-Channel Amps?
Feel free to give me any comments/sugestions because I am not at all an expert on car audio. Thanks guys for you help.
Old Jun 13, 2004 | 02:09 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Will this setup work out nice in my Jeep? (slvrcivic97)
Yes, replace that factory stuff. Factory systems always suck, no matter what nametag they glue onto the speaker grills.
As for the rest, I can't really help you. Its all a matter of opinion. I suggest you listen to other systems and see what you like.
Old Jun 13, 2004 | 02:41 AM
hybridzOr's Avatar
Default Re: Will this setup work out nice in my Jeep? (rochesterricer)
<also has a jeep, 95 to be exact and i have 2 15 kicker L7's and its death defying loud
one 15 l7 would be perfect in my opinion, as i was driving around with just one 15 for awhile til i got my 2nd l7.
im also running the kicker sx1250.1 amp. great combo for the l7('s)
Old Jun 13, 2004 | 06:57 AM
RallyRedGT-V6's Avatar
Default Re: Will this setup work out nice in my Jeep? (Hybrid Racer.)
I used to have a grand cherokee, and trust me, the stock speakers are actually the best I've ever heard in a car [well mine had the upgraded sound system from the factory]
2 12 type r's should be great, a friend of mine had both in his pathfinder and he was ridiculously loud when he wanted to be...clean too
Old Jun 13, 2004 | 07:21 AM
Default Re: Will this setup work out nice in my Jeep? (96integra)
thanks for the comments guys. That's the exact information i needed. So I'll probably end up getting an amp first, then the subs, then speakers last since the infinnity gold system will work for a while. So here's the revised version-What do you guys think?
I'm still confused on this OHM stuff...And I was told that if I get my component speakers, then I should get a 4 way amp??This amp stuff is really confusing me. Can someone clear this up?Because I'm getting the idea that I need to get a 4 way amp to power my speakers in my car and get another 1000w amp just for the subs.??Is this true??
Alpine 9833
1000Watt Amp to push the 2 12's.
1 ALpine Type-R 12" sub.
Component Speakers
Modified by slvrcivic97 at 4:59 PM 6/13/2004
Old Jun 13, 2004 | 09:45 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 &raquo;</TD></TR><TR><TD CLASS="quote">
I think you'd get better results if you went with type-X components up front and leave the rears stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
class D mono for the sub or subs and a 2 channel amp for the fronts. you can run the rears off the HU.
Old Jun 13, 2004 | 12:02 PM
Default Re: Will this setup work out nice in my Jeep? (EBP_SI)
awesome info!Thanks man. Just curious, why would you recommend the type x's over the type r's?Thanks. I kinda want the rears to sound good to though for the passengers. Will they still sound nice just running off the headunit and not a 4way amp?Thanks.
Old Jun 13, 2004 | 12:40 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 &raquo;</TD></TR><TR><TD CLASS="quote">awesome info!Thanks man. Just curious, why would you recommend the type x's over the type r's?Thanks. I kinda want the rears to sound good to though for the passengers. Will they still sound nice just running off the headunit and not a 4way amp?Thanks.</TD></TR></TABLE>
Well i would recommend the type-x over the type-R simply because they're better speakers and you woudl still be in the same price range if you skipped out on the rears. They X crossover has so many options as far as adjustability and levels
you could do a 4 channel amp and it would sound better but you're also looking at more money with that route. It would be a bit better but i think the front stage would overpower the backs and sitting in the front i doubt you'd notice a difference.
Old Jun 13, 2004 | 12:54 PM
Awesome. Thanks for the help man, much appreciated. I'll probably look into getting the type x front components with a nice 2 way amp. What kinda wattage should I be looking at the push the front components?
Old Jun 13, 2004 | 12:56 PM
bassisliffe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 &raquo;</TD></TR><TR><TD CLASS="quote">What Kind of amp should I be looking at?Mono Amp, 2-Channel Amp, or Mulit-Channel Amps?
class D for bass and anything but class D for mids
Old Jun 13, 2004 | 12:59 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome. Thanks for the help man, much appreciated. I'll probably look into getting the type x front components with a nice 2 way amp. What kinda wattage should I be looking at the push the front components?</TD></TR></TABLE>
that would depend on how much money you have to spend on an amp really. I'm giving mine about 130rms a side. i'd say anythign around 75-100 should be more than enough.
loup05
Audio / Security / Video
35
Oct 14, 2007 08:35 AM
zerovandez
16
Dec 6, 2006 05:57 PM
EVIL Hx Coupe
20
May 8, 2005 04:49 AM
stevenwest13
10
Jun 6, 2004 02:10 PM
