Viper 3203 question
Old Mar 5, 2012 | 12:40 PM
guyver13's Avatar
Default Viper 3203 question
below are the diagrams for the alarm; although I have already installed the alarm and all triggers work fine, the main siren and secondary piezo siren do not work at all (my guess I wired them wrong) along with my parking lights do not flash.
The car is a 94 integra coupe.
My question is, where exactly do I wire the siren's up to because all I see is a siren output on the main harness. Secondly which wire(s) for both the car and alarm to make my lights flash ( I know its supposed to be located in the door sill)?
just to note: before the install i tried to test out the sirens by hooking them up to my power drills battery and the peizo was loud and clear however the main siren didnt make any noise it just started smoking.
Below I have added a reference of how I wired up the alarms, and I assume this is correct.
Old Mar 5, 2012 | 11:13 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Viper 3203 question
Sound like you shorted out the main siren. And its shorting out the siren output as why the pizeo is not going off. And also you need to plug in the fuse into the alarm brain. Make sure you choose the polarity to what setup your doing.
Old Mar 6, 2012 | 10:42 AM
guyver13's Avatar
Was I correct in connecting the siren to the brown wires coming from the main harness, and which would be the best route to wire in kill switches
Old Mar 7, 2012 | 03:29 AM
NVturbo's Avatar
O.G. triple O.G.
For the parking lights, you need to connect the WHITE (alarm) to RED/BLACK (car) wire. This wire can be found at the dimmer switch, underdash fusebox or gauge cluster. Make sure the fuse leading to the alarm module (WHITE wire) is not blown.
rugimpy
Audio / Security / Video
12
Jan 22, 2010 03:06 PM
jiggatone
Lighting
Jan 27, 2008 07:47 AM
nickolas388
Aug 6, 2005 09:37 PM
ablack934doorcivic
Feb 8, 2005 03:49 PM
XtremeGirlRacer
Apr 11, 2003 04:57 AM
