Teggy Box
i have a JL 10w7 and i would like to mount it in the trunk some where in my 2001 ls Integra. i want to be able to use my trunk rather than having a giant box in the way. can someone please help me out and post some pics so that i can get some ideas? before i had 2 10" Rockford Fosgate HE2 in a box that weight like 150 with the subs in it. i had enough room in the trunk afterward for maybe 3 bag of groceries. granted yes the sound was awesome. but i think i have grown out of the super loud bass stage of my life. i am still wantin some good bass but i want my space too. i was thinkin maybe a false floor but that seems lie it would add alot of weight as well. please HT, give me some ideas!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">i have a JL 10w7 and i would like to mount it in the trunk some where in my 2001 ls Integra. i want to be able to use my trunk rather than having a giant box in the way. can someone please help me out and post some pics so that i can get some ideas? before i had 2 10" Rockford Fosgate HE2 in a box that weight like 150 with the subs in it. i had enough room in the trunk afterward for maybe 3 bag of groceries. granted yes the sound was awesome. but i think i have grown out of the super loud bass stage of my life. i am still wantin some good bass but i want my space too. i was thinkin maybe a false floor but that seems lie it would add alot of weight as well. please HT, give me some ideas!
</TD></TR></TABLE>The box for that sub is only 1.25cu.ft., biggest problem is the mounting depth, you need about 9" inside, [to clear vented pole] just build a basic box that will sit up against back seat, angle back of box to match the seat, face sub to the rear, mount box at the base of the seat with a piano hinge, that way you can flip the seat backs down, and if you need more room in the hatch you can flip the box forward. if you have the 4door you can go with a "false floor" use the spare tire well as the cabinet , and as most of the box would be fiberglass, it will be lighter then a conventional MDF box by more then half.
Remember this is a 500watt sub you need an amp that is at least 500 watts RMS so what ever box you build, it needs to be braced real good and the MDF needs to be sealed, the box needs to be airtight.
94
</TD></TR></TABLE>The box for that sub is only 1.25cu.ft., biggest problem is the mounting depth, you need about 9" inside, [to clear vented pole] just build a basic box that will sit up against back seat, angle back of box to match the seat, face sub to the rear, mount box at the base of the seat with a piano hinge, that way you can flip the seat backs down, and if you need more room in the hatch you can flip the box forward. if you have the 4door you can go with a "false floor" use the spare tire well as the cabinet , and as most of the box would be fiberglass, it will be lighter then a conventional MDF box by more then half.Remember this is a 500watt sub you need an amp that is at least 500 watts RMS so what ever box you build, it needs to be braced real good and the MDF needs to be sealed, the box needs to be airtight.
94
well i was wanting a ported box for this sub. personal pref i guess. i know that box has to be a bit larger just b/c, i'll look up how much space that needs. and also, if i make a box that has the same space but in a different shape, would that still work? or will it just be all sorts of screwy soundin? and please pics pics pics. i miss seeing my teggy cuz i've been deployed. stupid army!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">well i was wanting a ported box for this sub. personal pref i guess. i know that box has to be a bit larger just b/c, i'll look up how much space that needs. and also, if i make a box that has the same space but in a different shape, would that still work? or will it just be all sorts of screwy soundin? and please pics pics pics. i miss seeing my teggy cuz i've been deployed. stupid army! </TD></TR></TABLE> Thats OK,ported box is only a little bigger 1.5cu.ft. and yes it does make a diff. on what shape the box is, but the more angles the better, the worst box is a cube, the less parallel serfaces the better.
94
94
slowacura
Audio / Security / Video
11
Mar 7, 2004 10:43 PM
loki2323
Dec 18, 2002 09:09 AM
