swapping head units
I went from a 97 hatch to an 02 sedan. I know i need the metra dash kit but as far as wiring the head unit, do i need a new harness or could i just swap everything over plug and play?
its not a factor of buying a new one, im just not familiar with stereo equipment. I had my last install done at a shop. I diddnt know the harnesses could be swapped, or if i should just get a new one.
The harness you have works with civics up to '98 IIRC. They changed the plug in '99.
It's very easy to install the new harness. The aftermarket stereos and harnesses are all color coded the same, so it's simply a matter of color matching the wires.
i pulled the radio from my hatch and got the new dash kit and wiring harness. its the same exact harness. it could have been swapped. but i did notice my old one had 2 different connectors, this one only has 1.
My hatch was a 1997. The new car is an 02 LX. I ordered the scoshe dash kit and scoshe wiring harness. The connectors were exactly the same. I diddnt even open up the new wiring harness package, i just reused the one that was already on there. Ill save this new one for when i get a double din unit. maybe it changed in 96 when the 6th generation started? Cause mine was direct plug and play
No, it changed with the '99 - '00 facelift. If you you used the same plug on the harness both cars then someone swapped out the dash harness in the '97 for a '99 - '00 dash harness.
Has any one of you guys tried to install a double din in a 97 ek? I am thinking about changing my single din to a double.
Some 01 Integra still used the old plug while most changed over in 97/98.
It does not surprize me one bit the OPs 97 hatch harness is the same as his 02 sedan.
http://www.installdr.com/Harnesses/HA-Wiring.asp 94
That is a lot of work. I was also thinking of trading in my vehicle for a 2006 civic si. I was looking for navigation units and came accross ottonavis webiste. One of my friend told me he just purchased one for his 2007 accord from them and he really loved it. Anyone ever purchase from them or have any opinions on their navigation?
GSR-EG-92
Audio / Security / Video
Jun 15, 2009 11:52 AM
CivicRider011
Dec 10, 2006 07:07 PM
bmw626
Aug 24, 2005 11:47 AM
