sub wiring question's
Old May 12, 2006 | 02:48 PM
doggworld1233's Avatar
Default sub wiring question's
i am going to get 2 AW1251SE(audio bahn 12") with a box and a prymid(PB446X) 600w 2channel amp. first question will this set up work? the subs are DVC so how would i wire them to this amp remembering there are 2 subs. thanks . pictures or something will help for me to wire this up ,it is my fisrt time.
justin. these are going in a 95 civic coupe.
also does anyone know if them will hit hard in my car?
Old May 13, 2006 | 05:39 AM
can i have some help???
Old May 13, 2006 | 06:32 PM
Civic_808's Avatar
Default Re: (doggworld1233)
when wiring up the subwoofers to the subwoofer box...connect all the positive terminals of the subs to the positive terminal of the subwoofer box, then connect all negative terminals of the sub to the negative terminal of the subwoofer box...in your case since your pushing that amount of power i suggest 16 gauge speaker wire for this part...next wiring the subwoofer box to the amp...there should be 4 terminals total for power output for the amp (2 positive and 2 negative)...you are going to use the two outer terminals ( the outer positive and negative) connect the positive from the subwoofer box to the outer postive output on the amp and connect the negative from the subwoofer box to the outer negative output on the amp therefore bridging the amp (do this part preferably with 12 gauge speaker wire...as for your setup hitting hard in your car, that depends on your subwoofer box design and what frequency you tune the box...as for power with this setup you are under powering your subs...i checked the specs of your sub...they each start off at 400 watts RMS...with the amp you are only pushing 300 watts RMS per sub...sorry no pictures...if there is anything else....just ask....
Modified by Civic_808 at 4:24 AM 5/14/2006
Old May 14, 2006 | 04:50 AM
Default Re: (Civic_808)
my question now is will this be a safe setup? and since i am underpowering the subs will that make a big difference. i dont see that much in 100w less but i can be wrong. also these are 4omh subs if i was to wire them in pariell it would be a 1omh load and will my amp handle this?
thanks
are there any links to puting this stuff togerher?
Modified by doggworld1233 at 6:05 AM 5/14/2006
Old May 14, 2006 | 04:54 AM
also i would like to know. the subs are DVC so i will connect 4 pos and then 4 negs and then conect them to the cone on the box?
Old May 14, 2006 | 10:55 AM
Civic_808's Avatar
your amp is not 1 ohm stable...it wouldn't be good...so i don't suggest it...you should get an amp that has a higher RMS rating and at the same time that is also 1 ohm stable...try getting a mono-block amp...
Old May 14, 2006 | 10:57 AM
Civic_808's Avatar
heres a link that will help you out...
http://www.clubknowledge.com/Car_Audio_FAQ/?t33
Old May 14, 2006 | 11:47 AM
02 accord's Avatar
wire the subs in series/parallel, which will give you a 4 ohm load. Should give you more choices with amplifiers.
Old May 14, 2006 | 01:22 PM
Default Re: (02 accord)
ok i found how to wire it serier/paral and will give me a 4omh load will that work with the amp i want to use.also what are the dis advantages with using a smaller amp then the subs?
Old May 14, 2006 | 01:48 PM
Skip01's Avatar
Yeh thatll work.
Itll put out less power,assuming that 600x2 is rated at 2ohm,which most are.
Prolly be around 125-150watts goin to each speaker if u use that amp.Itll get them moving,but way short of their rms.
I would get another amp,prefer. a 1ohm stable amp and wire it parllel/parellel.
Hifonics,Planet Audio,Lanzar....to name a few on the cheaper side but still very solid amps.
Old May 14, 2006 | 02:12 PM
Default Re: (Skip01)
now my question is if i use this amp and sub combo do you think it will hit or am i wasting my time? i want a system that hits hard. i was also thinking of using PYRAMID PB536GX. is this a better amp ? and will it make my subs hit harder?
justin
Old May 14, 2006 | 02:40 PM
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">now my question is if i use this amp and sub combo do you think it will hit or am i wasting my time? i want a system that hits hard. i was also thinking of using PYRAMID PB536GX. is this a better amp ? and will it make my subs hit harder?
You could put that amp on it and itd sound ok,but ur still around 300watts from giving it its reccommended power.
Why are u stuck on Pyramid?Theres much better amps out there.
Me personally i wouldnt waste my time puttin that system together.Get a bigger amp.And youll be much more satisfied.
Old May 14, 2006 | 04:04 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 &raquo;</TD></TR><TR><TD CLASS="quote">
Me personally i wouldnt waste my time puttin that system together.</TD></TR></TABLE>
I concur. Audiobahn and pyramid are some of the worst brands out there. You can get much better subs than the audiobahns for about the same money.
Old May 14, 2006 | 04:57 PM
i only have 250 to spend on the system. find something better and cheeper
Old May 14, 2006 | 05:16 PM
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">i only have 250 to spend on the system. find something better and cheeper</TD></TR></TABLE>
I would save up a lil more and than do it right.
But if u have to you could use the subs,thats not really the biggest concern for me.
But please get a new amp,if u can use that $250 on just another amp itd be a big improvement.
Old May 15, 2006 | 02:22 AM
Civic_808's Avatar
audiobahn has some good **** out there...their higher end stuff is not that bad...their immortal and eternal series subwoofers are pretty good...i've heard them...i do agree with you on pyramid...i beg to differ on audiobahn though...thats my 2 cents on the topic so...
Old May 15, 2006 | 02:26 AM
Civic_808's Avatar
i agree with you on that...saving a bit more money and doing right the first time rather than spend a little first then spend some more later to re do the system...
2008fijibluesi
Honda Civic (2006 - 2015)
11
Jan 17, 2009 09:07 AM
deerman2701
Audio / Security / Video
Jul 4, 2008 08:09 PM
rollin92
Nov 22, 2005 12:33 PM
8point6
16
Apr 21, 2005 11:50 AM
92orangeeg
Feb 13, 2005 05:02 PM
