stereo diagrams?
i have a 94 del sol si and my power antenna doesnt do anything, i have looked at the antenna thingy (under the body) and the back of the deck, i dont see anything wrong with it. does anybody know of diagrams so i can check each wire?
i have a pioneer deck
Are you sure it's plugged in the back of the deck? What do you mean it doesn't do anything? Is it supposed to slide in on power-off and slide out on power-on and it's not doing that or what?
Should be a yellow/white, a white/yellow, and a black lead at the power antenna motor. Both the yellow/white and white/yellow should have 12v when the deck is turned on, black is ground. The antenna plug at the back of the radio has nothing to do with the power antennas funtion, only reception.
Does the antenna motor make any noise?
Kirk R
Kirk R
MestizoRacer310
Sep 18, 2002 08:58 AM
