Static Noise
Old May 31, 2002 | 05:09 PM
Unjockable's Avatar
New User
Default Static Noise
I just recently noticed a static noise when I listen to music. It's there when the volume is low and I can hear it when I listen to music without a lot of bass. Anyone know how I can stop the staic noise?
[Modified by Unjockable, 2:11 AM 6/1/2002]
Old May 31, 2002 | 08:01 PM
sparq's Avatar
Default Re: Static Noise (Unjockable)
Can you give us more info? What does your system consist of as far as products... all OEM or what? That might help us figure out the problem as it can be a million and one differant things at this point.
Old May 31, 2002 | 08:23 PM
turbocoupe's Avatar
Default Re: Static Noise (Teken)
$20 says your rca's and power wire are running on the same side of the car. . .that is if you are running amps.
Old May 31, 2002 | 11:06 PM
Unjockable's Avatar
New User
Q1: Is noise consistent with volume increase / decrease?
Q2: Does the noise change in pitch with increased engine RPM??
Q3: Can you hear this noise when the engine is off?
Q4: Does the noise make a poping noise?
Q5: When you select from CD to Tuner modes does the sound appear when the button is depressed?
Q6: What changes have occured in your system / automobile?
Answer all those Q's honestly after you *really* test each one... Then you will have your answer...
Regards
Teken
1. The noise is there when the volume is low. It's still there when the volume is high but you can't hear it as much since the music is louder.
2. No
3. Yes
4. No
5. No
6. I just recently got a Alpine 7894. I'm running 2 amps and a sub. A shitty amp for my speakers and a kenwood amp for my JL sub.
Old May 31, 2002 | 11:08 PM
Unjockable's Avatar
New User
Yeah, I'm running RCA wires on the same side of the car. It's not a wissing sound, it's static.
HondaScott
Honda Civic (2001 - 2005)
Oct 25, 2006 11:48 PM
devilpuppy
Audio / Security / Video
22
Jul 22, 2004 06:34 AM
