Is a starter switch useless in stick shift??
Old Aug 4, 2005 | 03:05 PM
hondamonkey's Avatar
Default Is a starter switch useless in stick shift??
Is a starter switch useless in stick shift because it can still be push started?
Old Aug 4, 2005 | 03:32 PM
PnoyJeff's Avatar
Default Re: Is a starter switch useless in stick shift?? (hondamonkey)
i wouldnt say useless
Old Aug 4, 2005 | 03:43 PM
nsxxtreme's Avatar
If your talking about a starter kill for an alarm then yes pretty much.
But the more you make the work the less likely your car will be stolen.
I would add at least
1) Starter kill
2) ignition kill
3) fuel kill
Old Aug 4, 2005 | 05:19 PM
Default Re: Is a starter switch useless in stick shift?? (nsxxtreme)
i dont think the question was answered yet? Anyone else have opinions and facts!!!
Old Aug 4, 2005 | 05:32 PM
junior40er's Avatar
Its not useless because at least you will decrease your chance of it having to be stolen. They would have to still get the ignition to on position THEN push start the car. So yes and no is the answer but its better than nothing. And like the other guys said its much better to add fuel cutoff swtich which is easy. If you dont know how then I can give you some help on that.
Old Aug 4, 2005 | 05:39 PM
Default Re: Is a starter switch useless in stick shift?? (junior40er)
i have the fuel cut off switch already just wanted to know if the starter kill that i have setup is gonna help against a potential theft attempt. As you said...they still have to get the ignition to the on position...but then if that is accomplished...then they can push start it...am i correct? With or without the starter kill a theif will still have to get the ignition to the on position? So wat is the use of the starter? Or does my switch have to be activated in order to be push started??
Old Aug 4, 2005 | 06:33 PM
anyone else?
David451
Aug 26, 2015 04:37 PM
Ep3Guy0z
Audio / Security / Video
Feb 8, 2013 05:53 AM
76 camaro car
May 28, 2011 12:40 PM
b18c1wes
Apr 18, 2008 08:44 PM
