speaker Install harness WOW!
Hey, I'm installing my speakers in my 1996 si "EX", and there are 2 blue wires... and 2 white wires in my door on the car harness thing.... can I just splice them and join the two blue together and two white together or???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">Hey, I'm installing my speakers in my 1996 si "EX", and there are 2 blue wires... and 2 white wires in my door on the car harness thing.... can I just splice them and join the two blue together and two white together or??? </TD></TR></TABLE>
I'd assume that there's two wires leading to your speaker because one set of blue and white wires are running to a tweeter.
They are probably wired in parallel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A »</TD></TR><TR><TD CLASS="quote">I'd assume that there's two wires leading to your speaker because one set of blue and white wires are running to a tweeter.
They are probably wired in parallel.</TD></TR></TABLE>
That is right, Just do a continuity test on the wires to see which ones are which. Then just don't use the ones for the stock tweets.
One set is from HU/amp the other goes to tweeter, [daisy chain] if you want to use the stock tweeter connect them together, like you said, or get the adpt. sp. harness from metra, [72-7800], or if your not using the stock tweeter, you can still use the adpt. sp. harness, [just unplug the tweeter] or cut the plug off and find the set that comes from the HU/amp and use them, [you can use a batt. to "pop" the tweeters] then use the other wires.
94
94
Import_spoon
Audio / Security / Video
Mar 20, 2007 09:36 AM
